It's the lower rear plastic molding... it rattles and can be annoying! Mine isn't bad most of the time but the other night I about pulled over to smack it! I'm going to pop it off and put some extra insulation in there, maybe dynamat.
It is the plastic under the window. Mine started to rattle a bit after the guys did my stereo install. I'll probably take it off and see if I can tweek it to make it stop.
Thanks for the response. I have a place to start looking. Does it come off easily? Pictures anyone? Anyone try spray foam?
BTW I recently did the Z06 Experience at Bondurant (what a blast) and I had noticed they had the rear window moldings off, didn't bother asking why? I now wonder if that was the reason.
