Yearly Oil Change
Old Nov 26, 2004 | 08:04 PM
gltrap54's Avatar
gltrap54
Default Yearly Oil Change
Although my manual suggests changing my oil every 12 months, regardless of the remaining life span, I'm tempted to fudge a little. Is this being penny wise & dollar foolish?
Old Nov 26, 2004 | 08:07 PM
gltrap54's Avatar
gltrap54
Default Oops
Oops we got two of em goin sorry............
Old Nov 26, 2004 | 10:15 PM
Rou-Rou 03's Avatar
Rou-Rou 03
Come on you own a vette not a VW. Please change the oil.
Old Nov 26, 2004 | 10:21 PM
Shortimer's Avatar
Shortimer
Yes, change that oil. I do my own oil changes and just did the work with only 11 months of use, about 2,600 miles. I didn't want to be crawling around in the cold weather so I changed it during a mild day in October. Yes, I drive my car in the Winter as long as the roads are free of salt and sand.
Old Nov 26, 2004 | 10:26 PM
CE2004's Avatar
CE2004
Change it to get the moisture and acids out of the crankcase, and off of your engine parts. In fact, I'd say to change it twice per year regardless of mileage for this very reason.
Old Nov 26, 2004 | 10:59 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I agree with the above. It's an expensive car and oil is relatively cheap. The life's blood of the car.
Old Nov 26, 2004 | 11:09 PM
kkr-c5's Avatar
kkr-c5
I change once per year, in the Spring... (1500- 2500 mi.)
Wheather it needs it or not...
K.K.
Old Nov 26, 2004 | 11:13 PM
IM QUIKR's Avatar
IM QUIKR
For the cheap SOBs out there, Pep Boys sells a calendar for $1 and inside is a coupon for 3 free Mobil1 oil quarts when you buy 3 quarts. 50% and the $1 goes to MADD, a good cause. Consider it a two for sale and stock up.
change the oil in spring and fall or sooner to protect the engine internals.
To Yearly Oil Change
