[Z06] Z06 Valve Train Noise
Old Jul 23, 2001 | 07:47 PM
av8or3's Avatar
av8or3
Hey fellas,I'm rolling into my third week with my new Z06.I'm very happy with the car and it's ALL and MORE than I expected.I have
one concern I'm hoping someone here has had experience with and can help me with (or re- assure me).
I hear valve train noise when driving.Most
noticable inside beginning just off idle and blending into the background by 2100 rpm.It
sounds almost like the engines of old with solid lifters,although I know the LS6 has hydralic lifters (which should have zero valve lash).Right?
Plenty of oil & oil pressure,engine runs like a scalded dog,no other problems.I love it!
Thanks in advance for any and all help you can pass along.For now I'll just turn the radio up and keep burning gas
Old Jul 23, 2001 | 08:22 PM
Ricker812's Avatar
Ricker812
That's just the way she is, do like me, turn up the tunes!
Rick out.
Old Jul 23, 2001 | 08:33 PM
wstory1's Avatar
wstory1
I agree, it's normal. I drown it out with the sound of the exhaust.
Old Jul 23, 2001 | 08:48 PM
Ranger's Avatar
Ranger
What they said.
It's a high performance engine that revs to 6500+ rpm and makes wonderful music at WOT. The throaty roar is integral to the experience. But so is a little engine noise at low rpm.
Ranger
Old Jul 23, 2001 | 11:32 PM
ArizonaZ06's Avatar
ArizonaZ06
Active Streak: 90 Days
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
After a few more hundred miles you'll start enjoying the valve train chatter.
I'm not kidding!
Good luck, have fun and don't care what others think.
99SSragtop's Avatar
99SSragtop
I know I don't have a ZO6 but I did put a Zo6 cam in my LS1.Is the sound you are hearing is a slight metal rapping sound.
Old Jul 24, 2001 | 12:39 AM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
The sound you described sounds like the noise from the injectors...
Carl
Old Jul 24, 2001 | 10:27 AM
Black2001Z06's Avatar
Black2001Z06
I've got this noise as well and have posted this same question. I and others have described it as valve train clatter, but as you stated, with the hydralic lifters, you shouldn't get that noise. I might lean towards injector noise, but at any rate, I've got 5K miles on my Z now and no trouble.
Old Jul 24, 2001 | 09:33 PM
av8or3's Avatar
av8or3
Here's something that will tickle your brain cells.A friend who builds Chevy engines
told me of a company that used to make hydralic lifters for high rise cams that were designed to bleed down some at low rpms
(in response to oil pressure) in order to reduce the lift/duration at idle.This would
result in a much smoother streetable engine
that would retain the Monster characteristics
of the big cam.As rpms (& oil pressure) increased the lifters would pump up and deliver the full lift/duration of the cam.
Hmmmm.....sounds good,what d'ya think?
Old Jul 24, 2001 | 09:57 PM
FastCars's Avatar
FastCars
Rhodes I think it was that sold these lifters... They do make a little noise from what I've heard but I haven't heard a lot of people recommend them.
Yup they make some noise when they bleed down but the Z06 cam is really not all that radical. Mine idles nice and smooth.
[/color]
Old Jul 25, 2001 | 12:18 AM
ZED-OH6's Avatar
ZED-OH6
Hey its a high performance car -its got a little valve clatter, a little tranny whine -its a bit balky going into 3rd and its got massive road and tire noise -but is it ever neat youll get used to it. .
01 QS ZED-OH6
To Z06 Valve Train Noise
