Question about passenger airbag
Old Nov 30, 2004 | 12:26 AM
Hawg's Avatar
Hawg
Default Question about passenger airbag
Is there a passenger airbag shutoff for C5's?
I'm considering selling my Wrangler and Harley and getting a C5 but if there's no way that I could put a carseat in the front (rare occasion but as a contingency nonetheless) then I'm screwed.
Stupid question maybe but have to find out before I get serious and am let down later.
Thanks.
Old Nov 30, 2004 | 12:30 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
mid year 00' and on have the shut-offs
I have an 00' and had to add it, get it from Ken Fichtner (here) It comes with a new belt, switch and all the wiring.
Here the install.
http://97vette.com/howto/airbag/index.html
Old Nov 30, 2004 | 12:33 AM
Hawg's Avatar
Hawg
Here the install.
Thanks bro.....after I posted I had the bright idea to actually search for the topic and low and behold.....it's been asked several hundred times already
With that in mind has anyone actually put a carseat in the passenger seat of their C5?? If so how does it fit?
Old Nov 30, 2004 | 12:35 AM
screw991le's Avatar
screw991le
I do, when he's not driving
As you can see, by his hand, I even added the stock light.
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
I use a carseat in mine fairly often now. My 5 year old has started using a booster seat, which is pretty easy to fit. snapping the belt buckle is a little more difficult than in our minivan b/c there is less room, but otherwise there are no problems.
Haven't seen any of your posts since I stopped coming around PRC :
Old Nov 30, 2004 | 12:40 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Old Nov 30, 2004 | 12:46 AM
screw991le's Avatar
screw991le
To Question about passenger airbag
