Oil Type
Old Nov 30, 2004 | 04:06 PM
Trocness's Avatar
Trocness
Default Oil Type
Had my oil changed today by my trusted mechanic. Manual states Mobil 1 5W30, ok for 10W40, but never 20W50. I live in So. Cal, so temp is not as critical as other areas. My guy put in Mobil 1, but 15W50. he says it is better for our region. Should I be concerned? I seem to be running higher oil pressure, around 50-60 lbs., when stayed around 40 lbs. before. Should I drain it out?
Old Nov 30, 2004 | 04:11 PM
Tom73's Avatar
Tom73
I would not use anything more than 10W30. I would have your mech replace it with the correct 5W30.
tom...
Old Nov 30, 2004 | 04:14 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
tom...
Peace
Willfulone
Old Nov 30, 2004 | 04:47 PM
GrayC5's Avatar
GrayC5
tom...
My '03 GM Service Manual states, "SAE 5W-30 is the only viscosity grade recommended for your vehicle." It does go on to say, "If the temperature range is 0*F (-18*C) or above SAE 10W-30 oil which has the API Starburst symbol is acceptable if SAE 5W-30 oils is not available. Areas where the temperature falls below -20*F (-29*C), it is recommended either an SAE 5W-30 synthetic oil or an SAE 0W-30 oil. Both will provide easier cold starting and better protection for the engine at extremely low temperatures." It specifically states, "Do not use other viscosity oils, such as SAE 10W-40 or SAE 20W-50 under any conditions." I think you will find that your owner's manual reads much the same.
Old Nov 30, 2004 | 05:17 PM
I would have the mechanic change it back to what is recommended by GM. There is nothing wrong with running 5W-30 oil in the car, especially in your area.
Old Nov 30, 2004 | 05:39 PM
Trocness's Avatar
Trocness
Thanks. I went back and had him drain out the 15W50 and put in the correct 5W30 (which I bought myself!). I feel much better now.
Old Nov 30, 2004 | 05:51 PM
srchief100's Avatar
srchief100
Happy endings are great
Old Nov 30, 2004 | 10:34 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Srchief...... Whats with that avatar hopefully thats not your pic
Old Nov 30, 2004 | 10:52 PM
Iron Chef's Avatar
Iron Chef
St. Jude Donor '06-'07-'08-'09
CI 8-9-10 Veteran
Oh that avatar...it's just...wrong
Old Dec 1, 2004 | 04:50 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
I use 10/30 but our summers are definitely more severe than yours in CA. 15/50 is overkill IMHO. Problem solved but he should have paid for the change if he was the one that f'd it up to begin with.
Old Dec 1, 2004 | 06:45 AM
Patman's Avatar
Patman
Out of all the Mobil 1 viscosities, their 0w40 is the best match for the LS1.
Old Dec 1, 2004 | 08:07 AM
Tom/99's Avatar
Tom/99
I don't use anything but 10W-30 oil, in all my cars. Since I have lived in Texas, the temperture has been as low a 9 degrees and as high as 110.
Old Dec 1, 2004 | 01:17 PM
JC in XTC5's Avatar
JC in XTC5
When I got the car and lived in Florida, only used 10/30. Even now in New England, the car is rarely used in the winter, and if I take it out the temps are above freezing, so I've stuck to 10/30.
With Mobil-1, the difference between 5/30 and 10/30 is almost neglible.
Old Dec 1, 2004 | 01:48 PM
Sportsdude's Avatar
Sportsdude
I just had my oil changed and went with full synth castrol 0-40w.
Old Dec 1, 2004 | 02:28 PM
mcronec5's Avatar
mcronec5
Cruise-In VII Veteran
Change the oil yourself, put the correct oil in, and find a new mechanic.
To Oil Type
