Is there a trick ...
Old Nov 30, 2004 | 06:25 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Default Is there a trick ...
to reattaching the airbridge to the top of the radiator shroud? I installed a Blackwing a few weeks ago, and could never get the two pins back in. I'm thinking that from the Blackwing back to that point is just too long, since the pins don't line up with the holes. There's a coupler (rubber hose, essentially) between the Blackwing and the MAF that had to be trimmed to 1.75", which I did, but it's still too long. And I don't want to cut too much off of it and not be able to hook everything together so it'll be held by the clamps.
Any ideas?
Old Nov 30, 2004 | 06:28 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
A lot of members have experienced the same problem. Most of them ride without ever attaching the Blackwing to the pins and rubber bushings.
Old Nov 30, 2004 | 06:32 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
So it doesn't rattle that way? It sure would be easier to take out and clean ... it's sort of a knuckle buster getting it on and off the pins.
Thanks.
Old Nov 30, 2004 | 06:33 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
If it rattles all the Halltech's would too. They don't even have the pins.
Old Nov 30, 2004 | 06:37 PM
PurpleHaze98's Avatar
PurpleHaze98
Strange I have never heard of that problem. Mine went in without a problem and doesnt rattle at all.
good luck though
Old Nov 30, 2004 | 06:54 PM
Patches's Avatar
Patches
Mine never completely seated when I was running the Blackwing but it didn't hurt anything. I totally pulled the plastic studs out of the top radiator shroud when I put my cf airbridge in. No harm.
Old Nov 30, 2004 | 07:09 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Blackwing as well - and mine doesn't line up either. Doesn't matter, IMHO
Old Nov 30, 2004 | 07:16 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I'll try either removing the bushings on the Blackwing, or removing the pins on the airbridge ... and maybe a little more tweaking on the alignment where components are clamped together. Right now, it's 'pooching' the center of the hood up a little in the front. Since some have not had this problem, it could be that the pins on all C5's were not aligned with exactly alike, causing the assembly to stand up somewhat.
Old Nov 30, 2004 | 10:15 PM
redzone's Avatar
redzone
Try loosening the clamps on the blackwing & the throttle body,push the airbridge into place,then tighten your clamps.If you have the clamps tight before hand it tends to put the airbridge in a bind.
Old Nov 30, 2004 | 11:16 PM
I noticed this on mine when I installed the Blackwing. I finally was able to adjust the air bridge to where it sat down on the pins almost as good as before. Took a lot of cussing to get it there though.
Old Dec 1, 2004 | 01:20 AM
shurite44's Avatar
shurite44
Default good technique
Old Dec 1, 2004 | 01:37 AM
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
Not that I know of.
Old Dec 1, 2004 | 06:40 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I guess those of us with the 97-00 cars are the lucky ones in this case. The Blackwing install for my car was a simple plug and play, everything lined up just like it came from the factory that way. I have it attached on the factory pins both on the top of the radiator and the front and didn't have to cut anything. I'll remember this the next time I recommend a Blackwing to someone :o
Paul
Old Dec 1, 2004 | 08:54 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I had the same problem when installing mine.
I went back and loosened all the clamps - positioned the blackwing on the studs (it worked) - and the retightened all clamps.
To Is there a trick ...
