how do I remove the DRL assembly?
Old Dec 2, 2004 | 05:06 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default how do I remove the DRL assembly?
the entire housing for the DRL, Markers, signals, etc...
never really noticed it before, but I just replaced my amber DRL bulbs with clear ones (looks better IMO), but inside both housings are about three exploded bulb fragments and one whole bulb (don't ask)
I want to get the entire assembly out so I can clean it out.
Old Dec 2, 2004 | 05:12 PM
wireless's Avatar
wireless
Photochop Terrorist
You might need to pop the whole fascia out?
Old Dec 2, 2004 | 05:16 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
I don't like that answer...
Old Dec 2, 2004 | 05:34 PM
Patches's Avatar
Patches
1) Raise and support the vehicle.
2) Remove the front fascia lower closeout panel.
3) Release the brake caliper cooling duct from the front fascia, and position the duct aside.
4) Remove the front turn signal lamp bracket retaining spring from the lamp bracket.
5) Remove the lamp bracket retaining spring from the front fascia.
6) Remove the front turn signal lamp bracket retaining screws.
7)Disconnect the sockets from the lamp.
8) Remove the lamp, with the bracket, from the vehicle.
9) Remove the lamp to bracket retaining screws.
10) Remove the lamp from the bracket.
Old Dec 2, 2004 | 09:59 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
thanks... have to try it this weekend
To how do I remove the DRL assembly?
