[Z06] NEED HELP! Problem with my shoft shifter.
Old Dec 4, 2004 | 07:42 PM
supra3z06Srt's Avatar
supra3z06Srt
Default NEED HELP! Problem with my shoft shifter.
Hi guys. I am having some trouble with my kirban short shifter. I always finding myself grinding while going into fourth gear. It always did this every once in a while since i got the shifter installed. I make sure I shift straight down into fourth, clutch all the way down before I shift and it still grinds sometimes. I have to put it back in neutral and then try again to make it go in. Was my short shifter not installed correctly or I just cant shift? Never had this problem in any other gear or any other car.
Thanks in advance.
Cal
Old Dec 4, 2004 | 08:19 PM
Teddy98Z28M6's Avatar
Teddy98Z28M6
Thanks in advance.
Cal
I have a kirban shifter and have no issues going into 4th gear. I would put the stock shifter back in and see if the problem is still there.
Old Dec 5, 2004 | 04:04 PM
supra3z06Srt
thanks if the problem still presist I will try that
Old Dec 5, 2004 | 04:15 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
It's a semi-common problem for the 4th gear synchros to go bad... this is what's causing your grinding when putting it in gear. They'll fix it under warranty (if you still have one) and put the upgraded steel shift forks in at the same time.
Old Dec 7, 2004 | 05:51 PM
supra3z06Srt
Went to the dealer about the grinding noise in 4th and they had 2 different techs drive it. Both could not find any problem with it. I guess it must me practicing bad driving habits. I sit a bit far from the petals and maybe Perhaps i get lazy... I'm shifting faster than I actual hit the clutch down. I guess I do need a bit more seat time in the z06 too. Imma make sure I pound that clutch down first before I do anything.
To NEED HELP! Problem with my shoft shifter.
