Key Question
Old Dec 4, 2004 | 10:26 PM
MyOwn69's Avatar
MyOwn69
Default Key Question
Bought mine used and was given 1 set of keys (actually, only 1 key plus the "buttons").
I'm not comfortable with only one set. Give me your recommendations for both another key and remote!
Thanks!
Old Dec 4, 2004 | 10:53 PM
Check with your local dealer. They can obviously get you both items. I'm not sure if the forum dealers will do this, but if you can find out the resistance of the chip in your key, they may be able to help you out also. Give Bob at Fichtner Chevy or Gene at Fred Beans Chevy a call and see what they advise.
Old Dec 5, 2004 | 12:29 AM
Tom73's Avatar
Tom73
Any good locksmith can duplicate the key. They have a "device" that can read the resistance of the chip so that they can match it up. The fob will have tocome from GM so check with a dealer.
tom...
Old Dec 5, 2004 | 01:16 AM
ALLEGRO's Avatar
ALLEGRO
Old Dec 5, 2004 | 02:35 AM
markcz's Avatar
markcz
You can usually get the blank keys with the resistor pellet on eBay for $25, then take the blank to your local hardware store to have it cut for $1. You just have to know the VATS code for your current key so you get the right blank. Find out the code by taking it to a dealer and paying for it, or use an ohm meter to check the resistance of the pellet yourself for free. Here are the code numbers that go with each resistance.
VATS Code -- Resistance
1 -- 392 ohms
2 -- 523 ohms
3 -- 681 ohms
4 -- 887 ohms
5 -- 1.13k ohms
6 -- 1.47k ohms
7 -- 1.87k ohms
8 -- 2.37k ohms
9 -- 3.01k ohms
10 -- 3.74k ohms
11 -- 4.75k ohms
12 -- 6.04k ohms
13 -- 7.50k ohms
14 -- 9.53k ohms
15 -- 11.80k ohms
Old Dec 5, 2004 | 02:45 AM
RENO's Avatar
RENO
That's good info!
Old Dec 5, 2004 | 02:51 AM
timwilson's Avatar
timwilson
you can buy the remotes off ebay as well i bought one used for $2.00 plus shipping just make sure the part number is the same and the owners manual tells you how to program it
Old Dec 5, 2004 | 03:44 AM
Sebring_C5's Avatar
Sebring_C5
I got a reputable lock and key shop here in town to do a new key and I found a like new remote on Ebay for a fraction of what the dealer wanted. Very easy to program the remote using the owners manual.
Old Dec 5, 2004 | 09:55 AM
repo's Avatar
repo
From: "when lightning strikes twice, the funerals insane, the funerals insane"
St Jude Donor '14-'15
The locksmith will cut a much better key than the dealer. Remotes are readily available on EBAY , just make sure you have the exact numbers on the cack.
Old Dec 5, 2004 | 10:05 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
1 -- 392 ohms
2 -- 523 ohms
3 -- 681 ohms
4 -- 887 ohms
5 -- 1.13k ohms
6 -- 1.47k ohms
7 -- 1.87k ohms
8 -- 2.37k ohms
9 -- 3.01k ohms
10 -- 3.74k ohms
11 -- 4.75k ohms
12 -- 6.04k ohms
13 -- 7.50k ohms
14 -- 9.53k ohms
15 -- 11.80k ohms
http://cgi.ebay.com/ebaymotors/ws/eB...category=40016
Paul
Old Dec 7, 2004 | 10:39 PM
Qcksilverc5's Avatar
Qcksilverc5
Default I went to Chevy dealer in Charlotte NC
They charged me $46 for the key---the fob would have been $100 more. I just got the key.
Old Dec 8, 2004 | 09:54 AM
paul99's Avatar
paul99
5th Gear
Default Try your Locksmith
I own a locksmith business and we duplicate VATS keys for $17.95.
We are in southern NJ.
Of course fellow Forum Members get a discount
Old Dec 8, 2004 | 09:59 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I went to the dealer for the key, but used Ebay for the fob. You just have to match your numbers on the back of your Fob to the ones they are selling. It doesn't matter if all the fobs are labelled number 1, 2 or 3 (I think all mine say 1).
Old Dec 8, 2004 | 10:01 AM
plaster's Avatar
plaster
What kind of turn around time do you have?
Old Dec 8, 2004 | 10:16 AM
MSGvette's Avatar
MSGvette
Old Dec 20, 2004 | 11:59 PM
AmIBadd's Avatar
AmIBadd
I found a locksmith that does this for $30.00. How do you go by finding the resistance, never done this. Any instructions, I have the meter.
Old Dec 21, 2004 | 09:04 AM
RCK1999's Avatar
RCK1999
You read the resistance across the chip on the key. As it reads, it will match up with one of the 15 resistance choices listed earlier in this thread. You get the corrosponding VAT number from the resistance reading.
Old Dec 21, 2004 | 09:24 AM
AmIBadd's Avatar
AmIBadd
Hmmm, looks like I need a digital meter.
To Key Question
