Battery problem
Old Dec 6, 2004 | 07:39 AM
bovette's Avatar
bovette
Default Battery problem
I can not seem to keep my 99 coupe's battery charged. I travel frequently so it is not unusual for me to not start the car but once every 2 to 3 weeks. But lately if I let it sit 2 weeks the battery is dead. I have checked to see if I am leaving an interior light on, which I am not. I even changed the battery 6 months ago and it is still doing it. Does anyone have any suggestions? Should I just unplug the battery? That's a pain in itself, I don't want to be resetting the LTPS all of the time. Please give me advice. Thank you in advance.
Old Dec 6, 2004 | 07:47 AM
Patches's Avatar
Patches
There is enough drain on the battery with the security system, etc. that infrequent driving can cause a problem - even with aftermarket batteries. Get a Battery Tender Plus and keep it hooked to your battery while the car sits.
Old Dec 6, 2004 | 08:00 AM
BobH's Avatar
BobH
I have my 04 at the dealers right now checking in to a battery issue. Mine first went dead about 5 months after I bought the car new. Last week it went dead again. The car was driven the week before. They are going to check to see if the car is drawing excessive volts when turned off. I suspect its the battery.. you can purchase a solar charger that plugs into your ciggy lighter and keeps it charged. I'll let you know what I find out when I get my car back.
Old Dec 6, 2004 | 08:08 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
I jsut purchased a 97 Red Truck and now spending a lot of time in it to see it completely restored...
...poor ol StuzVette is now often neglected for 2-4 days at a time...
it just barely started after the 4th day...
Normally I wouldnt encounter any similar issue...
Im now committed to driving StuzVette more often
Flight Test's Avatar
Flight Test
Cruise-In II Veteran
This might be a stretch, but check the glove box light. In many instances, the door does not depress the pin enough to turn the light off. I found this to be the case with my 2K. Hope this helps.
Old Dec 6, 2004 | 09:37 AM
bovette's Avatar
bovette
Where can I purchase the Battery Tender or the Solar Charger. Thank you in advance.
Old Dec 6, 2004 | 10:09 AM
Patches's Avatar
Patches
http://forums.corvetteforum.com/showthread.php?t=962798
To Battery problem
