Battery
Old Dec 6, 2004 | 11:25 PM
Dolen's Avatar
Dolen
Default Battery
Went to check the green eye on my 00, shined with a flashlight, none there, just black. Info on the battery advises charge before checking if black. If yellow, bad battery. What's up? Car starts, everything works, is it time for a new battery? I am presuming that its a original battery, has the side mounts and is the Delco 6 year. Any input would be greatful. Car has 29,000 on it, but I'm sure its the years not the miles. Thanks.
Dolen
Old Dec 6, 2004 | 11:28 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
WOW, GET THAT BATTERY OUT OF THE CAR!
Ok, as far as your reading i can give you no advise. Thanks to the GM engineering, your acid batter which is prone to leak near the side mounts, is right over your wiring harness. So replace your battery still good or not with a gel battery and never worry about it again.
Old Dec 6, 2004 | 11:36 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
You need to read this
Old Dec 6, 2004 | 11:39 PM
Dolen's Avatar
Dolen
Default Battery
Hey Stangkiller, Is the Optima Red top, a gel fill? Also, when you go to a top mount, does it require different cables? The positive looks like its long enough, but I don't know about the neg unless its tucked up somewhere. I don't see any acid leaks anywhere and the mounts look very clean and dry including the case.
Dolen
Old Dec 6, 2004 | 11:44 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Optima batteries are AGM (absorded gas mat) a.k.a gel filled. Their claim to fame is that they can even be mounted upside down and they won't spill. I'm not suggesting that, use the stock position to mount it!
The Optima batteries have the top terminals AND the side terminals. The RedTop 75/35 is a perfect fit for the C5. It's 720 cold cranking amps, which is more than the stocker's 600 CCA.
Costco has them all the time for $99.95 and it is a direct drop in. Optima also makes a 34/78 which also fits, (a little bigger), has the side and top terminals and is 800 CCA.
Optima makes a Yellow Top as well which is considered a "deep discharge" battery - generally used if you have aftermarket stereo equipment. But for the everyday starting application, you can't go wrong with the Red Top!
Get rid of that leaky P.O.S. before something bad happens!
Old Dec 6, 2004 | 11:55 PM
Dolen's Avatar
Dolen
Default Battery
Thanks for the info, I guess I better get that puppy out of there.
Dolen
Old Dec 6, 2004 | 11:59 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I just put a Red top 75/35 in mine today. $99 at Batteries Plus....if you have those up in GB.
Old Dec 7, 2004 | 12:00 AM
Dolen's Avatar
Dolen
Default Battery
Dolen again. On the Optima Red top mount, any change of the cables needed? Also being from Wis. Red or yellow?
Dolen
Old Dec 7, 2004 | 12:02 AM
Stangkiller
Dolen
I am running the Red Top as well, and it bolted right in.
Old Dec 7, 2004 | 12:03 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
The red top is a starting battery, that is what you want.
All Optimas come with both side and top terminals. Just use the side terminals...the factory cables bolt right up no problem.
Old Dec 7, 2004 | 12:16 AM
I too would advise switching the battery out. Get the Red Top and forget about it.
Old Dec 7, 2004 | 12:22 AM
CornNut's Avatar
CornNut
I have heard that the "eye" is only powered by one of the battery cells, and can be misleading on the charge of your battery. I would get an Optima, and save yourself the grief and the possible damage.
Dolen's Avatar
Dolen
Default Battery
Thanks to all. Y2k, yes we have Batteries Plus, will be there tomorrow.
Dolen
Old Dec 7, 2004 | 12:29 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Three to five years max on a battery and change it. Save yourself a lot of grief and other repairs. The alternator suffers trying to keep a degrading battery up to snuff.
To Battery
