[Z06] Trunk Release. HELP!!!
Old Dec 7, 2004 | 07:14 PM
Popclutch's Avatar
Popclutch
Default Trunk Release. HELP!!!
I was reading in another post about some guys having trouble getting a decent lift when they pop the rear hatch lid. My 02 has the same problem. Anybody know a fix for this other than adjusting the stops up?
Old Dec 7, 2004 | 08:25 PM
Shylor's Avatar
Shylor
Warranty issue.
Old Dec 7, 2004 | 08:27 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
Sometimes mine does that, and I just open and close one of my doors firmly with the windows up and it just pops the trunk open.
Old Dec 7, 2004 | 08:33 PM
Chuck Harmon's Avatar
Chuck Harmon
This is another case showing what a great resource the forum is! I had the same problem and came across an earlier post that suggested using white lithium grease from a spray can on the hinge mechanism. I doubted this would work because my hinges looked pristine, BUT IT DID!
I sprayed it on the hinges, wiped up the excess, and it now works perfectly. The spray flows really well into the hinges, then dries to a grease like consistency.
Chuck
Old Dec 7, 2004 | 10:11 PM
dragon84's Avatar
dragon84
WD-40 worked for me about 6 months ago, no issues yet.
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I had the same problem with my rear hatch lid.
All it took was a little lubrication to the hinge areas and it pops perfect now.
Old Dec 9, 2004 | 07:43 PM
Popclutch's Avatar
Popclutch
Thanks EVERYONE who replied to this thread!! GEE, do I feel STUPID!!! Simple fix, a little lube in the right spots! Good thing I'm a RETIRED aircraft mechanic!! LOL!!
Thanks again, Pop.
Old Dec 9, 2004 | 09:31 PM
Airwolf's Avatar
Airwolf
From: ********************* Florida's Space Coast *********************
Lube only helped mine for a short period of time. I added 2 springs on the lift shocks for an extra boost and it works great now. I picked these up a ACE Hardware (actually just one - I cut it in two) and then spun them on the shaft. The size I went with was a little under 2" long and they look to be 1/2" wide; about the same size as the strut. My trunk now pops great, cold or hot!
Just something to think about if lubing is NOT working. I can take a photo of the mod if anyone is interested.
To Trunk Release. HELP!!!
