"Pull Key, Wait 10 Sec" ???
Old Dec 8, 2004 | 09:57 PM
SLO VETTE's Avatar
SLO VETTE
Default "Pull Key, Wait 10 Sec" ???
"Pull Key, Wait 10 Sec": Just got this message on the DIC this morning on my new '04 Z06 (has about 4,500 miles). Thinking it was a precursor to column lock, I parked it, and took the beater car to work instead rather than get stranded...
Was it the precursor to column lock, or could it have been something else? The column lock actuator worked fine, engaging & disengaging no problem. But, I did not move the car in gear, so it didn't have the opportunity to potentially lock up.
Unfreakinbelievable. If it's column lock, it happened also on my '99 C5--after which I installed the bypass kit and never worried about it again. The GM engineer who designed this ought to be strung up by the short hairs. Better yet, Dave hill should be left in a bad, bad neighborhood with a C5 that's just gone into column lock.
In any event, I'm not driving the car until I install the Thunder Racing CLB kit in the trunk this weekend.
Suggestions appreciated. Thanks.
Old Dec 8, 2004 | 10:03 PM
I-SPEEED's Avatar
I-SPEEED
St. Jude Donor '19
Prelude to column block
Old Dec 8, 2004 | 10:07 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I suggest a beer while you install your CLB
Old Dec 8, 2004 | 10:09 PM
scott_fx's Avatar
scott_fx
if it locks up try putting in the key then put pressure on the wheel in a clockwise rotation and then turn the key. It unlocked my column when i had it lock up on me.
SLO VETTE's Avatar
SLO VETTE
now you're talkin!
Old Dec 8, 2004 | 10:45 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
looks as though that CLB will be installed sooner than you thought
Old Dec 8, 2004 | 10:47 PM
You're on the right track. Install the CLB.
Old Dec 8, 2004 | 11:19 PM
Joe's Eray's Avatar
Joe's Eray
Old Dec 8, 2004 | 11:25 PM
GrayC5's Avatar
GrayC5
Precursor to column lock - possibly, but not necessarily. Other conditions can cause this warning message to appear also. For example, this message can occur when the ignition key is removed and reinserted before the steering column lock system fully locks or unlocks the steering column. You may want to read what your owner's manual has to say about this warning message along with the SERVICE COLUMN LOCK warning message. Good luck.
Old Dec 9, 2004 | 01:15 AM
jjvet's Avatar
jjvet
The CLB will not work if you install it in the TRUNK.
Old Dec 9, 2004 | 03:44 AM
Cscokd's Avatar
Cscokd
lolol
Old Dec 9, 2004 | 03:48 AM
Sebring_C5's Avatar
Sebring_C5
I thought they got rid of the column locks Or is that just for auto's?
Old Dec 9, 2004 | 04:49 AM
FXWG's Avatar
FXWG
Old Dec 9, 2004 | 05:13 AM
Oskee's Avatar
Oskee
Veteran: Marine Corps
I would also make sure that the resistence chip on your key is clean because if the computer cannot read it you will also get that same message.....
Old Dec 9, 2004 | 06:26 AM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
I agree. I had the recall done and AFTERWARDS I started having problems with error messages. After 4-5 times I got the message, I switched to a newer key I had and have not seen the message since.
May be a coincidence but after doing the recall and another column related bulletin, it pissed me off that I started having problems then. I shoulda never touched it.
Mark
Old Dec 9, 2004 | 10:24 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I sure wish GM would address this craziness once and get it done. HOWEVER, I had the k harness done on my 2000 A4... from advice on the forum, got under bolster and unplugged portion that goes to column and verified that column was unlocked with key out and vette in Park( again, an A4 ) Still got the "pull key". Cleaned chip, same deal. What works for me is putting the key in and out of the ignition 2 or 3 times before attempting to start car. Doing it this way eliminates the "pull key". why? I dunno , but it DOES work in my case....
Old Dec 9, 2004 | 10:35 AM
'97 C5's Avatar
'97 C5
Mark
To "Pull Key, Wait 10 Sec" ???
Old Dec 9, 2004 | 10:50 AM
mrm1149's Avatar
mrm1149
We'll be reading about this into the next decade I'm sure... Good thing GM isn't in the NUCLEAR business !!!
Old Dec 9, 2004 | 11:49 AM
yellowvette837's Avatar
yellowvette837
St. Jude 15 Year Donor
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
mine locked twice and I never saw this message once.....
Old Dec 9, 2004 | 03:57 PM
Conk's Avatar
Conk
I agree.
I can unlock mine by shaking the wheel from side to side when turning the key. It has working both times the thing locked. Still, I'm installing the CBL soon.
