SS Inserts
Old Dec 9, 2004 | 03:02 PM
CO YGOSLOW's Avatar
CO YGOSLOW
Default SS Inserts
Couldn't find the thread...what prep is required to the paint surface prior to sticking the SS Inserts on?
Old Dec 9, 2004 | 03:12 PM
jrose7004's Avatar
jrose7004
Rub down the area with denatured alcohol and stick away, letting the alcohol dry or course!
Old Dec 9, 2004 | 03:19 PM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Thanks for reading my mind. I was about to post this very same question since my wife was hinting that she may get me a set for christmas. Thanks for the info C6 fever!
Old Dec 9, 2004 | 03:21 PM
roscoe118's Avatar
roscoe118
, and be careful with that prep stuff (for lack of a better term ) that they send with the letters, as it is a pain to get off if it is visible around the letters.
Oops! alex got in there between myself and jrose
Old Dec 9, 2004 | 03:33 PM
Alex1217's Avatar
Alex1217
Darn tootin partner!!
Fastest post slinger in the east!
Old Dec 9, 2004 | 03:38 PM
ALLEGRO's Avatar
ALLEGRO
Just don't be in a hurry!
Old Dec 9, 2004 | 04:11 PM
MagRed04C5's Avatar
MagRed04C5
And make sure that the center part of the two E's (they are separate small pieces) are inserted at the same angle as the outer part of the letter. Otherwise it will not reflect the same.
Old Dec 9, 2004 | 04:29 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
If only someone had told me ... but it's hard for people to see at +90 mph.
Old Dec 9, 2004 | 05:13 PM
BigJoe's Avatar
BigJoe
I wasn't too careful when I cleaned my letters. I used rubbing alcohol (a no-no I'm told now) and then plastered the goop they send with the letters all over. The result... the letters are on so tight that I doubt I can ever get them off if I wanted to. Yes I did have some of the prep goop that showed, but a bit of adhesive remover got it off quickly. I did mess up one of the E bars, though, so that is a good hint. Bottom line, take your time and don't worry too much. They are made so well it is hard to mess them up.
Old Dec 9, 2004 | 05:35 PM
Get some denatured alcohol (or rubbing alcohol will work) and really clean the area good. This will remove all wax in the letter area. Peel the protective strip off the letters and then stick them on. Should hold just fine.
Old Dec 9, 2004 | 07:53 PM
jrose7004's Avatar
jrose7004
There's an echo in here!
Old Dec 9, 2004 | 07:55 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Old Dec 9, 2004 | 10:30 PM
Z0SLIK's Avatar
Z0SLIK
Old Dec 10, 2004 | 09:43 AM
Boozman's Avatar
Boozman
It was a pain to get the prep stuff off is right it ran down the back and made a mess.
Old Dec 10, 2004 | 03:51 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Do you put the prep stuff on the letters after you peal of the paper backing...
or
Does the prep stuff go in the letter intentations on the back of the car???
Tks
Peace
Willfulone
Old Dec 10, 2004 | 04:11 PM
TruUndrtkr's Avatar
TruUndrtkr
i believe it goes on the indented area/back of the car 1st...@ least that what my instructions read...be real careful though..as noted in some of the above posts u can see the little mishaps that will result in a rushed effort...i have a little residue from the "glue" just outside of the intended area
Old Dec 10, 2004 | 04:42 PM
VetteSiNz's Avatar
VetteSiNz
Don't drink the remaining alcohol. j/k Just do it slowly.
To SS Inserts
Old Dec 10, 2004 | 05:21 PM
diyguy's Avatar
diyguy
Whats the diff between denatured and rubbing alcohol?
Would Vodka work --- don't have any denatured stuff on the bar?
Old Dec 10, 2004 | 05:35 PM
BobH's Avatar
BobH
You can use a Q-tip to put the alcohol on where the letters go. Makes things easier that way and it doesn't run all over the car. The letters look great btw!
Old Dec 10, 2004 | 06:18 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I don't think the denatured stuff has any nature left in it.
Sorta like single malt scotch.
