[Z06] What oil filter do you use?
Old Dec 9, 2004 | 07:30 PM
rpuerzer's Avatar
rpuerzer
Default What oil filter do you use?
Gm says that FRAM has no check valve and should not be used.
Old Dec 9, 2004 | 07:43 PM
TEXHAWK0's Avatar
TEXHAWK0
I think you only need a check valve to keep the oil from backflowing if it is not mounted with the base straight down as it is on the Z06. Some engines have the oil filter mounted on the side of the block in a horizontal position so you need the check valve.
Old Dec 9, 2004 | 07:53 PM
Z11409's Avatar
Z11409
check out www.oilfilterstudy.com
Old Dec 10, 2004 | 12:04 AM
EBZ0602's Avatar
EBZ0602
2015 C5 of the Year Finalist
St. Jude Donor '05-'10
I use the UPF44 Ultraguard Gold on my Z06, but I in the past used nothing but Fram and never had any engine failures or oil filters spittling apart!!
EBZ0602
Old Dec 10, 2004 | 12:14 AM
TheDVS1's Avatar
TheDVS1
I thought the check valve was in case the filter got clogged and allowed the oil to bypass the filter and thus keep flowing?
Old Dec 10, 2004 | 10:59 PM
gordy02corvette's Avatar
gordy02corvette
Check valves prevent or limit back flow & a bypass valve diverts flow. Which would be the case if the filter got clogged, damaged or the oil is thick such as when it is cold.
Old Dec 11, 2004 | 01:45 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
AMSOIL SDF filters in all my vehicles:
AMSOIL SDF Oil Filter
Part number for LS1/LS6 is SDF32.
Part number for other vehicles can be looked up here:
AMSOIL Online Product Application Guide
AMSOIL products can be bought by calling 1-800-956-5695 or using the link to the left. Please use reference #1206638 to ensure credit goes to my dealership and hence, this site. Thanks.
As a reminder, preferred customers save 20%. Again, please use reference #1206638.
AMSOIL Preferred Customer Program
Or, 1-800-777-7094.
Thanks for your support.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Dec 24, 2004 | 04:11 PM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
So whats the short term consensus?
Amsoil?
GM UPF44?
K&N with the removal bolthead?
(think Im out of the running with the K&N due to clearance issues)
Old Dec 24, 2004 | 05:22 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
UPF44 Ultraguard Gold.
Old Dec 24, 2004 | 05:40 PM
zeeman's Avatar
zeeman
For the ones who have posted they use the UPF44 Ultraguard Gold.....Which oil filter removal tool have you found to work best? For the ones on the Forum sho have removed the Factory oil filter for the first time...Was your filter extremely tight when trying to remove it? As I found mine to be ? If so, how did you manage to remove it? I had my Z16 up on the Rhino ramps last week...changed the oil, then when I tried to remove the factory filter to install the UPF 44...I had just bought the strap wrench which takes a 1/2" drive ratchet to turn the tubular frame the strap is attached to...but to no avail....Just managed to put a nice dent in the side of the factory filter...so,just left it on for the Winter storage and come Spring...will take it to the dreaded Dealer to attempt in removing it.....Sure would like to know the person responsible at the engine assembly shop who put that one on.......
Zeeman
Old Dec 24, 2004 | 06:20 PM
Z06-JIM's Avatar
Z06-JIM
Zeeman
I use one those bottom fitting oil filter removal tools that fits a 1/2" ratchet. It's formed to fit the bottom grooves of the filter and makes removal very easy.
Old Dec 24, 2004 | 06:46 PM
xilr8n's Avatar
xilr8n
upf 44 here also
You can just grab it with slipjoint pliers and crush it when removing it. I don't think the dumpster dude is gonna care.
To What oil filter do you use?
