Installing a skip shift eliminator
Old Dec 11, 2004 | 07:08 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
Default Installing a skip shift eliminator
where does it go exactly, relative to the oil filter? Got under the car today, but couldn't find the grey plug...
Old Dec 11, 2004 | 07:13 PM
ALLEGRO's Avatar
ALLEGRO
Should have come with insturctions. But on the driver's side of the tranny. Someone will surely give you a link to exactly "how to."
Old Dec 11, 2004 | 07:27 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
From the oil filter - head to the back end of the car. Here are pics of the process
Old Dec 11, 2004 | 07:35 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
that would explain it, i was looking toward the front of the car...the instructions that came with it are a copy of a copy of a copy, hard to read. thanks!
Old Dec 11, 2004 | 08:44 PM
Go to the back of the car, in front of the rear differential. The part that is bolted up to it is the transmission. Once you have found the transmission, look about 2/3rds of the way back on the tranny on the drivers side. Up near the top is a connector that is for the CAGS. Just unplug it, plug in the cap to seal the connector remaining on the tranny, then put the other part of the CAGS eliminator into the wires that come down. Then just zip tie the wires up away from the tranny and you should be set to go.
Old Dec 11, 2004 | 08:45 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
It goes ........................, ah I better not.......
To Installing a skip shift eliminator
