Vert top rubbing
Old Dec 12, 2004 | 09:06 AM
dgibson's Avatar
dgibson
Default Vert top rubbing
I have noticed my vert top is rubbing the paint at the base. Is there something I can do ? Looks like it has already dug into the paint. Tried waxing it out, but no luck. How can I keep it form causing any more damage ?
Old Dec 12, 2004 | 10:36 AM
CE2004's Avatar
CE2004
Cleartastic - they're a forum vendor...
Old Dec 12, 2004 | 10:43 AM
Tino's Avatar
Tino
Check this out ..
http://www.c5forum.com/cgi-bin/ultim...13.html#000000
Tino
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
using cleartastic would just be a "band aid".
you should adjust your top to prevent it from rubbing, and depending on what year your car is, there is a redesigned rear weatherstrip to correct this issue.
Old Dec 12, 2004 | 10:54 AM
CE2004's Avatar
CE2004
Just out of curiousity, what year is your rubbing Convertible? Later C5 model years were supposed to address this problem.
Old Dec 12, 2004 | 11:27 AM
gtzy's Avatar
gtzy
1998-2001: Service Bulletin: Paint Wear Through at Fifth Bow (Replace Seal)
Source: Chevrolet Dealer Service Bulletin
Number: 02-08-111-001
Date: 02/05/2002
Subject: Paint Wear Through at Fifth Bow (Replace Seal)
Model Year: 1998-2001 Chevrolet Corvette
Condition
Some customers may comment that the paint around the tonneau cover at the 5th bow is wearing through.
Correction
Replace the 5th bow seal using the following procedure:
Position the folding top with bows 1 & 5 in the up position.
Open the stowage lid and position the seats forward.
Close the top (with the stowage lid open).
Remove the right and left hand weatherstrip retaining nuts.
Remove the weatherstrip from the vehicle.
Install weatherstrip to #5 bow.
Install the right and left hand weatherstrip retaining nuts.
Position the folding top with bows 1 & 5 in the up position and reposition the seats.
Close the stowage lid and folding top.
Parts Information
Part Number
Description
10319827
Weatherstrip ASM-F/Top RR
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
B3160
Seal, No. 5 Bow- Replace
0.6 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
© Copyright General Motors Corporation. All Rights Reserved.
Related Forum: 1997 - 2003 Technical Discussion
User Comments
Old Dec 12, 2004 | 05:49 PM
dgibson's Avatar
dgibson
I have an '01 - thanks for the information - I had no idea there was a Service Bulketin out on this. I guess it doesn't matter that my warranty is out with a Service Bulletin, I could still get it fixed. Right ?
Old Dec 12, 2004 | 08:30 PM
gtzy's Avatar
gtzy
it would not be covered outside of warranty
Old Dec 12, 2004 | 08:48 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Sorry to say a service bulletin is not a recall notice which would be covered.
Old Dec 13, 2004 | 12:25 AM
GrayC5's Avatar
GrayC5
Good luck with the fix.
Old Dec 13, 2004 | 07:23 PM
Mr. Clean's Avatar
Mr. Clean
I had this same problem on my convertible. When I first noticed it, I purchased a clear static cling protector piece from Mid America. However, even though it was clear, It was too wide and looked crappy.
I then purchased some satin black "blackout tape" at the local auto parts store and had it cut down to 1/2" wide at a local body shop. They had a special tool for cutting the width of trim/striping tape. This tape is very thin and was easy to install, following the curve of the black plastic insert on the rear deck panel. The tape looks like a factory install and it protects the deck panel from the top rubbing.
I also adjusted the #5 top bow in accordance with the instructions posted in one of the above replies.
A few months after I did all that, GM came out with the TSB about the molding replacement and I had that done while the car was still covered by th eoriginal warranty.
I still have the satin black striping tape installed, even though the top does not rub anymore. When other convertible owners see it, they think it is a factory installed piece, so I left it on, just in case the top ever rubs again.
Sorry, no pictures at this time as the car is covered any and is hard to get to to take pictures.
To Vert top rubbing
