How to unplug MAF connection?
Old Dec 12, 2004 | 10:48 AM
drar15's Avatar
drar15
Default How to unplug MAF connection?
I've lifted the grey tab then tried to pry it off. I dont want to apply too much force and break it. How much force is needed to lift it off? Thanks.
Old Dec 12, 2004 | 10:53 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The gray tab slides out completely, it is just a lock tab. You don't bend or pry on it, just slide it out.
Old Dec 12, 2004 | 11:02 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Here's a pic from Dave68's Stinger install instructions. It should help.
Old Dec 12, 2004 | 12:28 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Depending on the year, that may not be the one he's talking about.
When I put my Halltech Stinger on my 98 coupe, there's some kind of little round sendor up near the throttle body that nobody told me about and I had no directions on how to get it out. It was a tee-total bitch. Its just pressed in but it's REALLY pressed in.
If that's the one you're talking about, try to GENTLY pull it out by the prongs. The center comes out and once it's out the outside will collapse and come without any trouble but be VERY careful. I broke mine taking it out.
Old Dec 12, 2004 | 12:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
You are correct. Pictured is the 2001/newer connection.
Old Dec 12, 2004 | 07:02 PM
drar15's Avatar
drar15
THANKS for the help. My install went smooth with no breaks.
Old Dec 12, 2004 | 07:06 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Love watching these success stories
To How to unplug MAF connection?
