"De-computing" a C5
Old Dec 12, 2004 | 06:11 PM
TampaWRX??'s Avatar
TampaWRX??
Default "De-computing" a C5
I'm curious just how much of the electronic monitoring and vehicle diagnosis sensors can be turned off via reflashes and/or inline resistors on the C5? I'm reading a LOT of threads which give me the impression that the vehicle management system on the C5 is very finicky and intrusive. I'm targeting a 99-00 FRC with minimal options as my ideal car and have little interest in traction control, power adjustable anything, tire pressure sensors, etc. Ideally, I would rein the computer in to the point that all it did was engine management and basic guage display functionality. Is this possible? Most imports are computer intensive as well, my Subaru having a particularly fiesty crank velocity sensor, but the C5 seems to be a nightmare for those of us that just want to make power and have no trouble monitoring the rest of our car's performance the old fashioned way.
Old Dec 12, 2004 | 07:52 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Why? You can turn off the traction control, tire pressure monitors do not affect engine power, remove standard seats and put in fiberglass shells to save weight.
Start messing with engine control sensors and outputs, and you may end up with either reduced power or a no start.
Old Dec 12, 2004 | 08:09 PM
On the road's Avatar
On the road
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Good question! I know you can turn off SRC with LS-edit and you can disable the skip shift too. I am sure there are other things you can do also. But the program isn't cheap. I think it's 250 for the base program and another 200 to 250 for the LS-edit program. And there are things you still need a scan tool for. Like cycling the ABS if you want to do a good job of bleeding the brakes. If anyone has more it would be helpful.
Old Dec 12, 2004 | 08:16 PM
NoelsTorchredZ's Avatar
NoelsTorchredZ
I just had LS1 edit done on my Z06. It was $300 with three dyno runs included. I wouldn't recommend messing around with the computer other then the LS1 edit. You start turning things off and you never know what it might effect. You sure don't want to mess with turning off the traction control especially if your coming from a WRX. Next thing you know you'll be wrapped around a tree, trust me, I've seen it happen!
Old Dec 13, 2004 | 12:45 AM
leaftye's Avatar
leaftye
I can understand wanting to eliminate VATS and CLB. Only problems with AH I've heard of is because of odd sized tires. ABS can go into ice mode, but I can't imagine getting rid of ABS all the time because of some rare freak problem that only occurs on the track.
Old Dec 13, 2004 | 01:24 AM
Dope's Avatar
Dope
Resident moron
Laptrax makes a nice little box that allows you to auto disable traction control everytime the car is started. I run it, it's nice. Like $99 or something.
You can use a Tech 2 to turn off tire pressure sensors, but quite frankly that's just plain stupid unless you want to lose 1oz per wheel.
Dope
Old Dec 13, 2004 | 05:37 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
I think trying to disable the electronics of a C5 would be very foolish.
Back in the 60's, we didn't have computerized engine management. We had carburators and 350 cubic inch engines put out about half the real net horsepower your C5 motor does, not even mentioning the emission controls that you'd have to fix in some way.
Yes, electronic engine management may occasionally cause problems but it's not a major concern. The problems you'd have and you'd create by attempting something like that would far exceed any maintenance problems you might have in the future.
Old Dec 13, 2004 | 06:04 AM
NSTG8R's Avatar
NSTG8R
I've had it happen on streets. :\ It's not very fun when you go to put your foot on the brakes and it wont engage. Something about being in a turn.
and as far as T/C or A/H goes, i haven't used it for months. I'm trying to find a way to disable it until I tell it to come on (bad weather). I thought I'd heard something about this somewhere.
and as far as disabling things in the c5, yeh .. it sounds like a b*tch to do.
Old Dec 13, 2004 | 06:20 AM
Tino's Avatar
Tino
I'm with Kyle on this one.
Old Dec 13, 2004 | 07:13 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
LS1edit is $500 per VIN, You need a laptop with a serial connection and a cable.
EG
Old Dec 13, 2004 | 08:00 AM
TTopJohn's Avatar
TTopJohn
I'm curious just how much of the electronic monitoring and vehicle diagnosis sensors can be turned off via reflashes and/or inline resistors on the C5? I'm reading a LOT of threads which give me the impression that the vehicle management system on the C5 is very finicky and intrusive. ......
Nothing about the computers on a C5 prevent you from making power the old fasioned way - more air and more fuel in = more power out
It's not as finicky as you describe above. Aside from column locks(get a Column Lock Bypass) and fuel gauge issues (which not everyone has a problem with), there aren't really any computer / electrical issues with the car.
Tire pressure monitors can be damaged when tires are mounted/dismounted. But they can be removed.
The stock PCM programming responds well to mods up to about a medium sized camshaft, and if you go beyond that to a cam lumpy enough to set a misfire code, an LS1 edit tune will work nicely. O2 sensors can be an issue depending on what kind of exhaust system you choose, but they can be turned off via LS1 Edit or replaced with 02 simulators.
As far as the active handling & traction control goes, just put it in competition mode and see how you like it.
Old Dec 13, 2004 | 09:47 PM
TampaWRX??'s Avatar
TampaWRX??
Thanks for the comments all. I've driven some pretty powerful cars and actually have some track training under my belt, so the power doesn't scare me. I'm more interested in making the car more basic with fewer potential gremlins coming from unnecessary accesories, etc. ABS is what it is and I am aware that it is a safety enhancement, but things like that are not totally necessary if you have respect for physics and a knowledge of what threshold braking, etc are all about.
I want to make sure to keep the computer handling the engine management, just wondering how much I can turn off in order to avoid owning a car that spends more time in repair bays with electronics issues than on the road chewing up tires and gasoline.
Don't worry, I promise not to toss the car off the road.
Old Dec 13, 2004 | 09:54 PM
Stock Man's Avatar
Stock Man
Actually our smog control inspection stations here hook into the OBDII port. I don't exactly know what they do. But if you start turning things off might affect your passing the test if they do this in your area. My .02
Old Dec 13, 2004 | 10:20 PM
leaftye's Avatar
leaftye
Isn't ice mode caused by using 18's in front with 17's in back, or even just oversized fronts?
Old Dec 13, 2004 | 10:35 PM
diyguy's Avatar
diyguy
TampaWRX
Your using at least one computer at home. You likely use a computer at the office. Everywhere purchase you make uses computers. Billions of dollars trade hands every day by computers. Many comercial aircraft and dozens of military aircraft could not fly without computers. Millions of cars are controlled by computer.
What would you guess the failure rate combined would be?
Maybe .000001%
I'd go with those odd's any day!
Old Dec 13, 2004 | 10:50 PM
TTopJohn's Avatar
TTopJohn
C5s don't have any issues like that. Electronic problems sidelining the car just doesn't happen as a matter of course. The Column Lock is about the only thing that shuts the car down, and it can be avoided with a column lock bypass.
Now, anyone driven an E65 BMW 7 series? Theres a car that sometimes has to be turned of and "rebooted" like a PC.
To "De-computing" a C5
Old Dec 13, 2004 | 10:56 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Just a comment on traction control/active handling... I've owned quite a few high performance cars for a lot of years. None had TC/AH until I got the C5 earlier this year. I REALLY like the AH feature. You can dirve the car considerably more aggressively and not have to worry so much about unintended 180s and the like from just hitting a bit of sand or gravel. Of course it is another system than can break/fail, but even though you are used to power and have track experience, you may find you like it on the street. Try to drive a car with it if you haven't. Just my $.02
Old Dec 13, 2004 | 10:57 PM
TampaWRX??'s Avatar
TampaWRX??
Originally Posted by diyguy
TampaWRX
Maybe .000001%
Believe me, I'm not anti-technology. I build my own PCs and work on several different platforms as part of my job. I'm just looking to disengage any unnecessary, whizbang stuff that is going to potentially get in my way. This is more a curiosity thing than a condemnation of the C5's reliability. The fuel tables for WRXes are ridiculous and the computer on my car is causing me issues right now, which is part of the reason I am exploring what is integral to the C5's systems and what is ancilliary. I want as primitive a beast as I can get, without losing the advantages of computer controlled engine management. I'm a minimalist.
Old Dec 13, 2004 | 11:00 PM
TampaWRX??'s Avatar
TampaWRX??
A friend of mine gave me a demonstration of the AH system just a couple of weeks ago. It's very cool stuff, but it just takes something away. I know it can be turned off and was probably a bad example to use in my original post. It was fun to have the car essentially bring itself back, even as we tried to take it well beyond the tires' grip potential in a hard 180. Neat stuff, but not something I'd like to break nor fix on one of these cars.
