Sway Bars ???
Old Dec 13, 2004 | 09:48 PM
UpToVT's Avatar
UpToVT
Default Sway Bars ???
I have a sorta Stock 99 C5 without the Z51 option. I want the car to handle better without spending Huge Moola. Should I upgrade the sway bars ?? How is the stock shocks ???
Is there a huge difference between the Z51 bars compared to the Gm t1 bars, compared to stock ???
Thanks for the information........
Old Dec 13, 2004 | 09:53 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
get the Z06 sway bars.
Z06 shocks wouldn't hurt either.
Old Dec 13, 2004 | 09:54 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
You could upgrade to ZO6 sway bars, will firm up the ride, but not to stiff for normal driving, if you want better than Bilstein shocks...we can keep going, but thse items should give want you may want.
Fred Beans usually has good pricing on these items
Old Dec 13, 2004 | 09:56 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I have the F-45 suspension but upgraded the sways to Z-06 bars and it's great.
Old Dec 13, 2004 | 10:02 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
I also have the F45 suspension and was thinking of looking for a set of Z06 sway bars. Was it a noticeable improvement?
Old Dec 13, 2004 | 10:06 PM
Tino's Avatar
Tino
How would the Z06 sway bars work with the F55 magnetic variable ride control? Has anyone tried this.
Thanks Tino
Old Dec 13, 2004 | 10:59 PM
leaftye's Avatar
leaftye
Big difference with T1 bars compared to anything. With T1 bars, you'll understeer more with stock size tires. Unless you have a track-modded car, Z06 or Hotchkis bars are as far as you want to go. Z06 front spring and '04 shocks are a good idea too. If you're going for a track setup, I wouldn't go any further.
Old Dec 13, 2004 | 11:03 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Old Dec 13, 2004 | 11:07 PM
mhaber's Avatar
mhaber
I have an 02 with the stock suspension. I switched to Z06 and it's the best mod for the money that I've done. You won't regret it. You'll need to get the aluminum end links. Check out prices at Fitchner.
http://www.corvetteforum.net/c5/kenf...rtspage1.shtml
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
We went with Hotchkis Sway Bars & QA1 12-Point Adjustable Shocks
Old Dec 13, 2004 | 11:15 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Hotchkis sway bars, Bilstein shocks, lowered, Z51 springs, Sportsbrakes, GM ceramics.
Handles like crazy!!
Old Dec 13, 2004 | 11:23 PM
MikeJamesC5's Avatar
MikeJamesC5
Hotchkis sway bars and Bilstein shocks.
Old Dec 13, 2004 | 11:28 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
That's what I have, too....
Old Dec 13, 2004 | 11:44 PM
RUBYREDVET's Avatar
RUBYREDVET
Thanks Tino
Changed to Z06 bars front & rear on my 50th AE MN6 and I really like the difference. Still rides great but corners flatter.
Old Dec 14, 2004 | 12:54 AM
DirtyRed's Avatar
DirtyRed
I have 01 vert with F45 susp. Upgraded to T1 bars and alum endlinks. Car corners very flat . I have heard that folks feel the ride would be harsh but I haven't found that to be the case. I drive everyday on all sorts of roads and the car feels normal going straight, but on rails going round turns. "Try it, you'll like it!"
Old Dec 14, 2004 | 01:19 AM
Dirty Howie's Avatar
Dirty Howie
I have the Hotchkis bars and F55.......Huge improvement in handling.
I am going to lower my ride and thought Bilsten Sports were THE shock of choice. Can you fill me in on the QA1.......how it compares to the Bilsten in price/performance....keeping in mind I need to cut front bushings.
Old Dec 14, 2004 | 01:42 AM
MTV's Avatar
MTV
Thanks Tino
With my F55 suspension, I went beyond Z06 sways, to Hotchkis Sways and Z06 Springs + Z06 4 wheel alignment. Results: Big Time Fun! Best,
mtv
To Sway Bars ???
Old Dec 14, 2004 | 03:01 AM
blackbelt's Avatar
blackbelt
t1's are insane can't wait to get mine.
Old Dec 14, 2004 | 05:15 AM
FiberglassFan's Avatar
FiberglassFan
Hotchkis sway bars and Bilstein shocks will be installed on my 98 Coupe. the Bilsteins will be first, cause it needs them. I'm not getting adjustable shocks and stiffer springs cause I already have one car with a full race suspension and its really uncomfortable on regular roads at less than racing speeds. I expect the B-Steins and bars will firm it up a bit in the curves but keep it reasonable for trips and daily driving. If you go into the older posts via the search function you will find a HUGE amount of info about this, and that is why I have chosen the Sport B-Steins and Hotchkiss. If you are lerry of the stiff Hotshkiss sways, the slightly softer Zo6 bars can also be a good choice, much more sporty response than stock bars. Jennifer
Old Dec 14, 2004 | 06:14 AM
Tino's Avatar
Tino
Just what I wanted to hear, so this spring, on top of my Ti's, I will also buy a set of Z06 sway bars.
Tino
