Rattle ?
Old Dec 14, 2004 | 11:03 AM
BLACK02's Avatar
BLACK02
Default Rattle ?
I've Got A Rattle Under The Car When I Turn Off The Engine.any Ideas ? It Sounds Like It Comes From The Exhaust. Is This Normal.
Old Dec 14, 2004 | 11:07 AM
CN RED's Avatar
CN RED
It might be your exhaust plate. It's the aluminum plate that runs directly under your car. I do believe it's called a "Exhaust Plate". I was in the Car Aduio section and the guys over there were commenting about vibration or rattle from under the car when they add a sub. The common problem was a loose exhaust plate.
CN RED
Old Dec 14, 2004 | 11:10 AM
Patches's Avatar
Patches
It's normal. If you've got an MN6, push the clutch in before you shut the car off. Quiets it down.
Welcome to the forum.
Old Dec 14, 2004 | 11:13 AM
Fastgenious's Avatar
Fastgenious
If you have the 6-speed, it rattles when you turn off the vette. If you engauge the clutch while turning off, you should not have the rattle. Very common on a manual vette.
Old Dec 14, 2004 | 01:22 PM
Could be the exhaust - you may be able to find it by raising the car and testing the exhaust by shaking it. Try what Patches said also - could be the problem.
Old Dec 14, 2004 | 01:27 PM
ALLEGRO's Avatar
ALLEGRO
Old Dec 14, 2004 | 01:28 PM
jdplays's Avatar
jdplays
Default .
it's just the clutch, normal sound
Old Dec 14, 2004 | 03:20 PM
tixin's Avatar
tixin
Hey...Thanks!! I was just thinking about that weird, very brief rattling noise when I shut down the car.
To Rattle ?
