Crazy question, but has anyone tried water injection.
I know some rally cars use it overseas and it's standard on some Saab models.
Worked at a WWII aircraft museum and the aircraft recip engines used it.
Supposedly it works great on turbo and supercharged engines and on FI engines and aspirated engines it produces 25-30% more HP.
Just wondering.
I had the Spearco system back when I had my Talon. It was a simple but effective unit.
I don't think it makes any power per-se, but on FI it allows you to run more boost as it cools the charged air. I am not sure if it can be used on NA engines...perhaps others have tried it?
i think he might be talking about water injection into the cumbustion chamber area...allowing the temps to drop and allow for more fuel/power...they did this with the WWII aircraft to get more power from them. It was also used on many passenger airliners that had turbin engines (same concept), they would use the water for take off mainly, and they would go through thousands of gallons really quick.
red
Exactly! They still H2O inject jet engines for greater thrust.
Supposedly there is a company called Aquatune or something like that that make a system.
I was reading a bit about it regarding rally cars and everyone seemed pleased with the operation of these water systems and the power they produced.
One factor that has to be considered is that water vapor in the intake makes the available charge more dense (heavier) and thus slower to move. The theory for power is to suck the maximum qty. of air + fuel inside the cylinder on the intake stroke, so on n/a engines the H20 is going to slow the rate at which the charge can enter the cylinder as well as consume space that would otherwise be filled with fuel vapor. Without forced induction the only benifit I,d see from the water would be controling detonation, through cooling the temp of the cylinder, and then the water would clean away carbon deposits from the combustion area sort of like a steam cleaner. The carbon deposits can contribute to detonation. So the only possible increase in power would be if you could advance the ignition timing because the detonation was eliminated better.
you need to consider that the H2O will also allow for much more denser air to be allowed to enter the combustion chamber, this may negate the "heavyness" of the increased density.
I had a 68 Big Block Buick years ago with a 10.25:1 compression ratio. The Spearco Water Injection prevented pre-detonation/pinging and allowed you to advance the timing a few clicks.Could not really tell if the engine made much more horsepower or not.
Lingenfelter has recently added a water injection system to their twin-turbo 427s. By doing so the engine's horsepower rating has been increased from 750 to 850. The system they use is manufactured by AquaMist.
AquaMist's literature states that their system can be used on naturally aspirated engines.
