Its so easy to work with. Got 3 rolls at Home Depot @ $12.99 a roll. I used about 4 1/2 in my vert. Cut sound fairly well. Well worth the effort, probably my cheapest effective Mod>
lowe's item # 28929 (called Thermwell Foam and Foil Duct Insulation
Item #: 28929, Model: FV516) is same as Frost King. It is $14.74 per roll. The link below will take you directly to it on the Lowe's website:
Home Depot has the same item but calls it Frost King. It is Home Depot item number 473855. Enter the number in the "search Hole" on their web site: http://www.homedepot.com
