Rough idle
Old Dec 16, 2004 | 11:30 AM
diyguy's Avatar
diyguy
Default Rough idle
Noticed while sitting at stop lights (some very long), in neutral (MN6), the engine feels like it is missing every now and then. Almost sounds like it has high perf cam, but definately just rough idle. Around 800 RPM
Once the RPM's come up, isn't noticeable, but suppose it still could have a mis-fire - just don't feel it in higher RPM's.
There are no codes in the DIC, current or past... starts right up every time.
Stat's: 99 coupe. MN6, 50k miles, almost 100% stock except for B&B PRT's. Bought a couple of months ago. Everything works on it - ZERO issues, other than the rough idle.
Ideas? Thoughts?
Old Dec 16, 2004 | 11:53 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I've got a 99" LPE coupe it's in neutral or park the idle is a bit rough, but its the cam. Other than that I don't notice it a bit.
On my 63' SW the cam was quite huge so I noticed it all the time with the clutch in. That's until you squozze down on it.
Old Dec 16, 2004 | 11:59 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
I'd check the air intake make sure it's nicely sealed. Maybe change the plugs. Good luck on finding the rought idle!
Old Dec 16, 2004 | 12:05 PM
BigJoe's Avatar
BigJoe
Well... it IS a high performance cam. My 2000 would do that quite a bit at idle. you could feel the car rock side-to-side when it was just sitting there. My Z06, if anything was even "worse". However I don't notice it on my '04 (may just be used to it by now). It is probably just your car trying to tell you it is ready to run...
Old Dec 16, 2004 | 12:38 PM
Mr. Jones's Avatar
Mr. Jones
they do rock a little. If it has original wires and plugs its time for replacement.
Old Dec 16, 2004 | 12:44 PM
Hiteck's Avatar
Hiteck
My 99 shakes when sitting in neutral. You can't see it from outside, but you can feel it sitting inside the car. I figure it's a sportscar, so I guess it should shake and rattle a little.
Old Dec 16, 2004 | 12:56 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
If it just feels like it misses a little it is common. I can even feel it in my moms 01 and it is an automatic. I think it is fairly common in a lot of GM vehicles (don't know about other companies). I have a 00 Silverado automatic and it does it at stop lights as well. Kaley
Old Dec 16, 2004 | 01:00 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Mine is new but I changed the plugs and wires and it smoothed out quite a bit. Also check the MAF and gently clean the wire.
Good Luck
Peace
Willfulone
__________________
..................Click for
Old Dec 16, 2004 | 05:16 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
...this coming from a guy who has a rough idle and wont do anything about it
...what he said...
...and check that plug wire connected securely...
Old Dec 16, 2004 | 09:13 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
bad wire....it should shake a bit but if it is more noticeable than usual...check the wires....probably one going bad
Old Dec 16, 2004 | 09:45 PM
diyguy's Avatar
diyguy
If is has a rough idle, does that also mean when you want to "blow out the carbon", is it not getting full power, or is it just an idle problem?
Old Dec 16, 2004 | 09:57 PM
JTS97Z28's Avatar
JTS97Z28
my 99 FRC with 20K miles does the same thing. Car runs very strong no issues except kinda choppy idle it seems. One of these days I will throw in some decent wires and plugs. See if that helps any. Im not to worried about it though.
Old Dec 16, 2004 | 09:59 PM
Tombone's Avatar
Tombone
Do your Rpm's fluctuate at idle?
Old Dec 16, 2004 | 10:03 PM
Sixguns's Avatar
Sixguns
These engines need to re-learn the idle now and then, I dont recall the exact method but you basicly allow the enigne to idle about 10 min. the shut off the engine and start it back up, and the computer will do the rest.
To Rough idle
