~~WTF are these??~~
Old Dec 17, 2004 | 09:24 AM
NewfieC5's Avatar
NewfieC5
Either remove access panel in wheel well or you can reach down from above when the hood is up.
Old Dec 17, 2004 | 09:26 AM
IM QUIKR's Avatar
IM QUIKR
Originally Posted by USA-VET
look at my pics posted above, front fender wells
9 - 7mm screws hold that panel on. It is located behind the driver's front wheel. I've had mine off without lifting the car. Once the screws are off and you work the panel out, turn the wheel left and you'll have lotsa room.
Old Dec 17, 2004 | 09:27 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Udders man, udders.
They are there to act a a drain for your air intake.
Reach under the master cylinder and roll them back a bit and clean them often (leaves and small children) or water can back up and kill your wiper module.
atl97vette's Avatar
atl97vette
From: You want HOW much for that Corvette part??? Atlanta GA
Originally Posted by C5naples
Drain tubes for the cowl area
Old Dec 17, 2004 | 10:41 AM
ROADAPPLE's Avatar
ROADAPPLE
If you don't keep these cowl drain tubes clean they will plug up, durring a hard rain the cowl overflows and the water shorts out the windshield wiper circut board inside the windshield wiper motor mounted just below the cowl area.
Been there, done that. Paid for it.
Old Dec 17, 2004 | 11:13 AM
NXTFAZE's Avatar
NXTFAZE
WERD
Old Dec 17, 2004 | 11:35 AM
iceburgh's Avatar
iceburgh
St. Jude Donor '03-'04-'05-'06-'07-'10
Old Dec 17, 2004 | 11:38 AM
vmspionage's Avatar
vmspionage
Originally Posted by CAJUNY2KC5
Yep. Those are drains for the cowl area and can be clogged with leaves and crud. When OOH YEAH did my screens we found a Yule Log and a small dog stuck in one of them.
If not kept clean, water can back up and flood the area where your windshield wiper motors are and mess them up.
They were designed by GM's resident dairy farmer.
I found out what they were when my wipers stopped working. They had clogged up and flooded the motor and gearbox which had to be replaced.
My tech suggested just cutting the bottom part off but I yanked them out completely. My vette doesn't need udders
Old Dec 17, 2004 | 11:50 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Originally Posted by ooh yeah
I've done many sets of screens for friends and those are always full of crap. I think thats where all the rice burners go when you blow by them.
...found a ricer in mine just the other day...
drain from cowl...and terrific design to clog as it drains
Old Dec 17, 2004 | 01:23 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by jdmvette
Nads.
Old Dec 17, 2004 | 01:35 PM
pocorojo's Avatar
pocorojo
Brian, where'd you get the screen set? They look good. I'm interested in a set for my 97.....Thanks
Old Dec 17, 2004 | 02:03 PM
ecook's Avatar
ecook
Why can I not see any picture's
Old Dec 17, 2004 | 05:58 PM
  #33
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Found a fruit cake dated 1935 in mine. Must have run over it.
Old Dec 17, 2004 | 06:02 PM
  #34
Stickman81's Avatar
Stickman81
Are they on both sides of the car? I thought I heard that somewhere.
Old Dec 17, 2004 | 11:01 PM
  #35
USA-VET's Avatar
USA-VET
here ya go, great guy & he is a Forum Sponser
http://www.vetteshop.cc/default.asp?...38&NID=1866067
Old Dec 17, 2004 | 11:02 PM
  #36
USA-VET's Avatar
USA-VET
Nope. just the drivers side!
Old Dec 17, 2004 | 11:08 PM
  #37
CAJUNY2KC5's Avatar
CAJUNY2KC5
Originally Posted by drcoffee
To clean them, just yank them down and out. They pop out and in very easily. Clean them and reinstall and you're done.
Tried that method. Ever heard a car scream OUCH!!????
To ~~WTF are these??~~
Old Dec 18, 2004 | 12:57 AM
  #38
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
They look like C5 nipples, C5naples. Are you sure they are drain tubes for the cowl area?
Old Dec 18, 2004 | 07:49 AM
  #39
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
The moral to this thread is "drive your Vette on sunny days and never, never, ever park it under a tree."
Old Dec 18, 2004 | 12:42 PM
  #40
diyguy's Avatar
diyguy
Is there any reason why that can't just be left off?
I found mine under the hood sort of wedged between the brake master cylinder and asked "WFT" is this for?
Now I know!
