Pink Fluid
Old Dec 17, 2004 | 07:41 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Pink Fluid
Anyone with an A4 had this happen?
A dreaded pink fluid spot appeared on my garage floor.
I'm taking it in for service this a.m. and have it checked as I don't want to diaper my baby.
Not alot yeasterday, just about 1/2 a teaspoon full, then one drop on a sheet of white paper this a.m.
Can't tell exactly where its coming from, but it appears to be the pan gasket. (loaned out my jackstands)
My neighbor is a mechanic and he said that sometimes with the Hot/Cold of winter, been running 19 degrees here in Ohio, that the A4 pan has to be retorqued.
Anyone ever had the same problem?
Appreciate it.
Old Dec 17, 2004 | 07:46 AM
Patches's Avatar
Patches
Jim, you can retorque the pan yourself easily. Tighten the transmission oil pan bolts alternately and evenly to 97 lb. in. (11 N·m). While you're under there, you'll probably be able to locate the source of the leak.
Old Dec 17, 2004 | 08:01 AM
Benpup's Avatar
Benpup
Morning Patches,
Best of the season to you.
I loaned out my jackstands or you know where I'd be this afternoon. Hope that's all it is. If not I've got 4 1/2 years left on a 5 yr 50k extended.
I'm in for an oil change today anyway and the dealer I take it to lets me do what I want under it while I'm there. (In fact he has no other choice or he'd never see a $ of my business again.)
One of their new Service Managers told me one time that their insurance would not let me back in the shop. I told him my insurance covered me and told the kid putting it up on the lift to bring it down. He changed his tune quick.
The mechanic that works on Vettes for them, he's my age (old) just hands me a wrench sooooooooooo!
I'll keep you posted as to what I find.
Best to you and yours.
Old Dec 17, 2004 | 08:40 AM
MyOwn69's Avatar
MyOwn69
I loved their classic rock album "The Wall."
Oops, that's FLUID - my bad!
Hope it turns out to be something VERY simple - and cheap!
Good luck!
Old Dec 17, 2004 | 08:50 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Transmission fluid is a myth. Set upon us by the big auto companies so that they can extract more money from your pocket.
I choose not to use transmission fluid, and my C5 has run fine for 5 months.
That'll show em.
ps- I'm kidding
Old Dec 17, 2004 | 10:45 AM
Shinyredone's Avatar
Shinyredone
I had the same thing. Put it on a rack, thought it was the pan leaking. Tightened the bolts, next day still leaking, back on the rack for a closer look, turns out to be the shaft seal (left) from differiential. Funny thing is it quit leaking....
Old Dec 17, 2004 | 11:17 AM
roscoe118's Avatar
roscoe118
Damn 69, you beat me to it
Benpup, hope it is nothing serious. Doesn't appear that it will be. Sounds like you got a dealer as well
Old Dec 17, 2004 | 12:04 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
St. Jude Donor '05-'06
Good luck!
though the same thing as you
Old Dec 17, 2004 | 12:10 PM
mrgil's Avatar
mrgil
Burnout
Default Leak
You better check the fluid level 'cause if it stopped it might be EMPTY.
mrgil
Old Dec 17, 2004 | 01:46 PM
Leo3's Avatar
Leo3
undefinedundefined
Appreciate it.
Old Dec 17, 2004 | 01:51 PM
Leo3's Avatar
Leo3
This may be a long shot but a friend of mine had a very unusuall transmission leak.He is on another fourm. Please e:mail me for more information because i dont know all the rules here. Basicly the output shaft had an extra hole in it that cause the leak.
Good Luck & Happyl Hollidays for everyone in this fourm.
Leo
Old Dec 17, 2004 | 02:13 PM
m1k3's Avatar
m1k3
Appreciate it.
I looked at your profile and noticed you have a '99.
This may be a silly question, as I'm no expert mechanic, but are you sure you're not seeing Dexcool leaking from the water pump?
Old Dec 17, 2004 | 04:21 PM
Hope they find and fix the source of your leak. At least thankfully it is under a warranty.
Old Dec 17, 2004 | 07:12 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
If I saw Pink Fluid on my garage floor I think I'd be Un"Comfortably Numb" about it.
Patches has the answers you need........
To Pink Fluid
