Key Question
Old Dec 20, 2004 | 02:23 PM
AmIBadd's Avatar
AmIBadd
Default Key Question
Is there some place to order a new key for the C5 other than the dealer?
Old Dec 20, 2004 | 02:37 PM
madelko's Avatar
madelko
Yes, I just ordered one on eBay - Paid $26 - You have to supply the vendor your Vats code - I got that off the Forum and if you know how to measure Ohm resistance, you've got it covered.
I have the list of Codes if you can supply me the resistance I will e-mail you.
madelko@southslope.net
Old Dec 20, 2004 | 02:56 PM
RCK1999's Avatar
RCK1999
Any GOOD local locksmith should be able to set you up. They can even read the VAT code if you have a sample key. I found a local one in San Antonio that took about 10 minutes and about $25 to set me up with another key. NOTE: they were even REALLY nice about it. Its amazing: dealers charge you DOUBLE and treat you like crap (INHO)!
Old Dec 20, 2004 | 03:11 PM
AmIBadd's Avatar
AmIBadd
Thanks guys, you put me in the right direction.
Old Dec 20, 2004 | 03:18 PM
csexton's Avatar
csexton
Eckler's has them for $14.99!!
Old Dec 20, 2004 | 05:12 PM
plaster's Avatar
plaster
http://forums.corvetteforum.com/showthread.php?t=962351
Check out the 3rd to last reply. If you use him, let me know.
Old Dec 20, 2004 | 05:16 PM
A well stocked Locksmith shop should have some. You can also get them from places like Ecklers (although you need to know the resistance of the chip in the key). Ecklers may not be any cheaper than your dealer though.
Old Dec 20, 2004 | 09:06 PM
WilliamCall's Avatar
WilliamCall
I bought a blank key from Ecklers ($14.99). Took it to the local Lowes home center, they cut the blank key (no charge).
To Key Question
