Dumb question on torque readings…
Old Dec 20, 2004 | 11:38 PM
Vette 4 Fun's Avatar
Vette 4 Fun
Default Dumb question on torque readings…
Math question, does 12 in/lbs = 1 ft/lbs??? Therefore if I were to use my in/lbs to tighten a 10 ft/lbs, I could just set it at 120 in/lbs???
Thanks!!
Old Dec 20, 2004 | 11:46 PM
RedWolf's Avatar
RedWolf
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09
Someone correct me but I believe you are correct in your math and your thinking.
Old Dec 21, 2004 | 12:54 AM
I X L R 8's Avatar
I X L R 8
I heard tell a ft/lb can be compared to dropping a 1 pound hammer (minus the handle) from X height.
The force at which the hammer strikes the ground in relation to height will equal foot pounds.
thus 30 ft/lbs would be the equivilent force of a 1 pound object hitting the ground from 30feet
I think this may make ft/lbs a bit easier for everyone to understand.
Old Dec 21, 2004 | 01:10 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Merry Christmas. And there are no absolutely no dumb questions here. Happy New Year.
Old Dec 21, 2004 | 01:27 AM
RandW's Avatar
RandW
Or, I think, a foot pound is the pressure of 1 lb. at the end of a one foot bar. In other words if you need 300 ft. lb and you weigh 150 lbs you would use a bar 2 ft long and hang on the end!
Old Dec 21, 2004 | 01:28 AM
Cscokd's Avatar
Cscokd
Thanks!!
The answer to your question is "yes"....Here you go...no need to guess about it:
http://www.pitt.edu/~rsup/touqueconv.html
just enter your number in foot pounds and click on the > for your conversion answer....hope this helps
John
Old Dec 21, 2004 | 02:12 AM
Vette 4 Fun
Thanks all for the input, and John for the great link!!
Old Dec 21, 2004 | 09:52 PM
ROJ#79's Avatar
ROJ#79
John
Great information!
Old Dec 21, 2004 | 10:02 PM
michach1's Avatar
michach1
Precisely.
Old Dec 21, 2004 | 10:08 PM
Dr. Dan's Avatar
Dr. Dan
I looked at this question as an aging brain problem. I only wish that I could retain everything, but I've only got 1.2 Gb of memory and it is crammed with Crap.
To Dumb question on torque readings…
