Running Car During Winter
Old Dec 22, 2004 | 07:33 PM
PeteTheGreek's Avatar
PeteTheGreek
Default Running Car During Winter
I'll drive my C5 in the winter if the roads are clean and dry, but lately we're having some pretty good snowfall here in Columbus, OH. IS it OK to start the car and let it run for a few minutes every week or so or should I just get a battery tender and drive it when the weather clears? A friend of mine who owns a 911 told me not to start it and let it sit in the garage because condensation in the oil may damage the engine. Thanks and Happy Holidays to All!!!
Old Dec 22, 2004 | 07:49 PM
REDRWUT's Avatar
REDRWUT
it's ok to drive it in the winter. if you plan on doing so, make sure you get all of the internals hot( oil,coolant,transmission) and you will be fine. just starting it for a few minutes and shuting it down would not be good. this is when you get condensation in the internals.
also you give the tires a chance to keep their roundness.
This is just my opinion.
Old Dec 22, 2004 | 07:55 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you're gonna run it, but can't drive it, at least back it out of the garage and let it run at least 15-20 mins until it's up to normal operating temp. (at least 200deg. oil temp).
Only running it for a few minutes is much worse for the engine than not running it at all.
Old Dec 22, 2004 | 07:56 PM
noel48's Avatar
noel48
St. Jude Donor '14
Old Dec 22, 2004 | 08:00 PM
Patman's Avatar
Patman
Don't start your engine unless you're planning on driving it for a half hour or more. In the cold weather you'll never get the oil temperature hot enough by just sitting and idling. And idling is not good for the engine either, you'll just end up with more carbon in the combustion chamber.
You can leave the engine unstarted for the entire winter and it'll be fine. When I had my 98 Firebird Formula I stored it in the winter and one year it went 4 solid months without being started. In the spring it fired up first crank and made no strange noises at all and ran smoothly. No harm done. So why do you guys think it needs to be started?
Old Dec 22, 2004 | 08:03 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
You were lucky after all that time that your car started.
Old Dec 22, 2004 | 08:08 PM
Patman's Avatar
Patman
I did use a battery charger on it occasionally to keep the charge up, so there was never any doubt that it would start up without a problem. My only fear was that the engine might make some strange noises from it having sat for so long but like I mentioned, it sounded perfectly fine.
Old Dec 22, 2004 | 08:10 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Where my car is parked at the moment I have no electricity to keep a tender on it, and don't wish to take the battery out.
I typically drive it once every 2 weeks or so to keep the battery charged and keep everything fresh and moving.
I agree just running and idling isn't be the best solution, it should be driven, but if it's been sitting a few weeks w/o a charger, you best get it started now while you still can. And if you do so, at least get it up to temp...and yes, it will reach temp w/o driving it.
Old Dec 22, 2004 | 09:21 PM
REDRWUT's Avatar
REDRWUT
Seals tend to dry for 1. When the engine sits for a long period of time you lose your oil film.
i just sold my last "Baby",an '87 Choo Choo w/44k on it and it sat through long storage periods. Everything just starts to deteriate from non-use.
wouldn't do it again.
Old Dec 22, 2004 | 10:19 PM
Just use the battery tender unless you can get the car out and get her up to operating temp. This includes the oil, coolant, and other fluids like differential and transmission.
Old Dec 22, 2004 | 10:43 PM
2 LOW 4 YOU's Avatar
2 LOW 4 YOU
run it a few mins first
To Running Car During Winter
