Cold Wx = Strange Electronics?
Old Dec 22, 2004 | 11:12 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Cold Wx = Strange Electronics?
My car is a 2001 Coupe with about 55,000 miles, original battery.
When I shut down the car at the airport three days ago the DIC was blank, the HUD was showing speedometer and oil pressure.
Today I got back to O'Hare after a three day trip, the temperature was about 6'F. The car started just fine, no evidence of a low battery. But after startup the DIC showed the odometer reading, and the HUD had added the tachometer to the display.
I was able to reset everything to the normal readings, but I'm wondering what (if anything) this means. The easy answeer would be that low battery voltage somehow caused the settings to change, but the engine sure seemed to crank normally despite the cold temps. So I'm not so sure about a voltage issue. Any ideas? Thanks.
Old Dec 22, 2004 | 11:24 PM
wpdjoey's Avatar
wpdjoey
didnt leave the keys with a valet did ya
I'd guess your battery is beginning to show signs of failure too. May want to get it checked.
Old Dec 22, 2004 | 11:29 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The HUD always has the tach display..doesn't it? Mine only toggles between oil press, coolant temp, and fuel level. The tach bargraph never goes away.
I think the DIC setting changed to whatever your memory setting is when you unlocked the door with the fob.
The battery didn't get low enough to chenge settings and somehow come back to life in 6 deg. weather enough to start your car, no way.
Old Dec 22, 2004 | 11:39 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
That sounds like the battery is dying.
As far as the HUD you have 3 settings
1. speed
2. speed and tach
3. speed tach and oil/water/fuel.
Change that by holding the page button down a little longer.
When to hit the page button quickly it only toggles the oil water fuel
Old Dec 22, 2004 | 11:41 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
1. speed
2. speed and tach
Well gawdamn, I've owned this car over 2 years and I never knew that.
Old Dec 22, 2004 | 11:42 PM
screw991le's Avatar
screw991le
Thats why this board is great, learn something new every day.
Old Dec 23, 2004 | 08:25 AM
Gearhead Jim
St. Jude Donor '13
No valet!
If the battery is dying, the problem should recurr any time it gets cold outside. So I can wait and see if this happens again. Or if I take it in to have the battery tested, how accurate is the testing?
I have seen newspaper articles say that gel batteries like in the '01 tend to last a long time if they make it through the first couple of months. Any experience on that?
To Cold Wx = Strange Electronics?
