[Z06] '04 Fuel System Question
Old Dec 23, 2004 | 10:23 AM
l2vette's Avatar
l2vette
Default '04 Fuel System Question
I have read from other posts that the '04 Z06 fuel system has the C6 technology. Is it true and what is the change, if any??
Thanks,
Old Dec 23, 2004 | 05:00 PM
l2vette's Avatar
l2vette
ttt.
Anyone know??
Old Dec 23, 2004 | 07:49 PM
C6~Missle's Avatar
C6~Missle
Thanks,
It is true that the Z06 uses the same fuel system as the new C6. I don't know exactly what the changes are...
mike
Old Dec 24, 2004 | 04:56 PM
l2vette's Avatar
l2vette
mike
Thanks Mike.
What are the C6 Fuel System changes??
Old Dec 26, 2004 | 01:13 PM
xilr8n's Avatar
xilr8n
I found this in one of Hib Halverson's articles on the C6
The C6 fuel filter is inside the left fuel tank. It was moved there during the 2003 model year at about VIN 11,000. The move was forced by the U.S. Environmental Protection Agency's (EPA) continuing pressure on car companies to reduce evaporative fuel emissions and, perhaps, for ease of manufacture. It's hell if the filter has to be replaced due to an unforeseen problem with fuel contamination, such as debris, water in underground gasoline storage tanks or vandalism.
To replace the filter requires pulling the fuel tanks and before you can do that, you have to remove the transaxle and driveline. Now, service technicians will undoubtedly develop methods other than those in the factory service manual to shorten their time on the job, but the fact remains that the "flat rate" time charged for the job will probably include driveline and transaxle removal. As a fuel contamination problem due to outside influences would not be covered under warranty, I'd be damn upset if my C6 had to have a job costing many hundred dollars to change a filter costing a few bucks. That, also, is an expensive burden to the customer and not very smart. You can thank the green-jihadists at EPA for that.
Also in the tech notes from gm there is new fuel line connectors on 2004.5 and 2005 corvettes
Old Dec 26, 2004 | 02:32 PM
slong's Avatar
slong
Default Not true!
Not true! The C6 has the 04 technology. If original question is true.
Thanks,
To '04 Fuel System Question
