Fuse box cover
Old Dec 25, 2004 | 10:44 AM
RWH's Avatar
RWH
Default Fuse box cover
First off Merry Christmass everyone! OK this is minor delema (sp), what is the trick on getting the screw off that holds down the fuse box cover? I have a chrome cover to go over the stock cover and need to get the hold down screw off.
Old Dec 25, 2004 | 11:26 AM
white top's Avatar
white top
there is a plastic shaft around the screw as I recall that has slits that run length wise to the screw. The trick is to spread the plastic shaft to release the screw. Be careful I cracked mine doing this. Probably better if the part is somewhat warm.
Jerry
Old Dec 25, 2004 | 11:39 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
the plastic thing that looks like a drywall anchor is the key. I slit it with a razor knife on two vertical sides till I could spread it. The **** portion will then come out. To reinstall I just put a small electrical tie around the circumference of the plastic "anchor" to pull it back together. Hope this makes sense ..
Old Dec 25, 2004 | 11:42 AM
RWH's Avatar
RWH
Thanks guys, I know this isn't rocket science but it I would rather ask the question than break something I would have to replace. As always this forum is a wealth of info. THANKS again
To Fuse box cover
