Battery Tender
Old Dec 25, 2004 | 11:29 AM
Tino's Avatar
Tino
Default Battery Tender
I went to a local Canadian Tire store here in Ontario looking for a battery tender but no such luck. I bought a small device called a "Trickle Battery Charger" that has 1.5 amp automatic operation that switches from full charge to float charge mode and then monitors the battery. I have never had one of these devices and want to make sure it does not overcharge and cause the battery acid to leak. Does this description sound similar to a battery tender and is it okay to leave it on all winter? Here is a picture of what it looks like.
http://img.photobucket.com/albums/v4...0-1038_IMG.jpg
Tino
Old Dec 25, 2004 | 11:57 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
somewhere in the manual it should tell you... my guess is that it should not overcharge. if your vette is at home maybe just turn it on a couple times a week or contact the manufacturer with your specific question..........
Old Dec 25, 2004 | 12:04 PM
Big Sugar's Avatar
Big Sugar
I just bought the same one at Cdn Tire a couple of months ago...its charging the battery from my '90 on my workbench as we speak...it will flip into "maintenance mode" once its at full charge and will do so whenever the charge drops to a certain point...they cover it in the instruction sheet but u have to dig for the info.
Quick edit...I had to buy a pair of posts to properly connect the charger to the battery...they are right next to the chargers at Canadian Tire...couple of bucks...not sure if you'll need them, just an FYI...
Old Dec 25, 2004 | 12:23 PM
srwelsh's Avatar
srwelsh
The very same charger as the Sears Diehard Battery Charger Maintainer sold in the USA. Just a different label on the front. I have the Diehard and it works perfectly. Being fully automatic with 1.5 A slow charge they are designed to be plugged in and forgotten about without harm of overcharging.
Old Dec 25, 2004 | 12:48 PM
Fast98's Avatar
Fast98
Try sears I have one of them it works great
Old Dec 25, 2004 | 01:14 PM
Tino's Avatar
Tino
Thanks for all the input, I believe this one is made by the same manufacturer that makes them for Sear's. I will put mine on as soon as it warms up a touch. The battery currently reads 10.8 volts.
Tino
Old Dec 26, 2004 | 12:43 AM
dooscoop32's Avatar
dooscoop32
My Battery Tender works great.
CRVETTE
Old Dec 26, 2004 | 12:46 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
After the battery dying with 3 weeks of setting, I decided enough of that. I've had the Battery Tender Plus for a couple of years and have had no regrets. You should be okay with that one. You just want to stay away from a trickle charger...it MAY overcharge your battery and cause it to leak.
Old Dec 26, 2004 | 08:18 AM
What you have bought should work just fine. The automatic setting should not allow it to overcharge the battery.
Old Dec 26, 2004 | 09:13 AM
JPEAK's Avatar
JPEAK
Tino
Tino, Not too hard to find. I purchased my Battery Tender Junior in 2003 at a Kawasaki bike dealership here in Guelph Ontario for about $55.00 CAD. Probably any large dealership in Richmond Hill should carry these accessories. If not, try Two Wheel Motorsport in Guelph 519-836-1957. If you go onto BT web site they will list types of dealer who will carry them. You can also try a Harley, Yamaha dealer too.
Old Dec 26, 2004 | 09:31 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
CRVETTE
Old Dec 26, 2004 | 10:14 AM
66427-450's Avatar
66427-450
Originally Posted by srwelsh
......the Sears Diehard Battery Charger Maintainer ......it works perfectly. Being fully automatic with 1.5 A slow charge they are designed to be plugged in and forgotten about without harm of overcharging.
agree, i just picked up a couple more, ~30$us each.
Old Dec 26, 2004 | 11:53 AM
1BAD-LS1's Avatar
1BAD-LS1
I have the battery tender - he's a link to a site that sells them:
http://www.batterymart.com/battery.mv?p=DEL-021-0156
To Battery Tender
