Question About A Squeaky Belt?
Old Dec 25, 2004 | 02:11 PM
Beardown3's Avatar
Beardown3
Default Question About A Squeaky Belt?
I have a 2000 C5. Recently, what appears to be a squeaky belt sound is coming from my engine. The serpentine belt looks fine. Does anyone know what could be causing this sound. It's driving me crazy and I wish I knew how to fix it my self before going to the dealer. Any suggestions would be greatly appreciated.
P.S. There is no leaking that I c an see from the car and its actually worse in the morning when I start the car and gets somewhat better after I have driven for a while. There doesn't appear t o be any leaking from the water pump. Thanks in advance
Old Dec 25, 2004 | 02:31 PM
Jimbad's Avatar
Jimbad
St. Jude Donor '06-'09-'10-'11
Merry Christmas. You really can't tell if a belt is good by its looks
(maybe if its bad the appearance will so indicate). To determine whether or not the belt is causing the squealing just spray water on it with the car running. If the noise stops you have found the culprit.
Old Dec 25, 2004 | 02:37 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
changed my belts at 60K and the noise I had went away..
Old Dec 25, 2004 | 02:43 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
I have a squeaky sound also from the engine compartment gotta give the water trick a try
Old Dec 25, 2004 | 02:50 PM
Fast98's Avatar
Fast98
Try a goodyear gator back belt that woked on my 98.
Old Dec 25, 2004 | 02:59 PM
Beardown3's Avatar
Beardown3
Default Okay, water spray made it go away
temporarily, so it must be the belt , right? Do you think I can hav e anyone switch that out or should I take it to the dealer. Looks as if though we're only talking about one long serpentine belt. Recommendations?
Old Dec 25, 2004 | 03:44 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
I would recommend a Goodyear Gatorback Belt.
It's an easy job most anybody can do.
You take the tension off the belt, slip it off and install the new one.
I believe there is a diagram under the hood that shows the belt route.
Old Dec 25, 2004 | 04:49 PM
Autoworker's Avatar
Autoworker
Changed out mine at 50,000. Bought them online at Rock Auto and got a good deal . Go ahead and change both belts while you got the front belt off.
Old Dec 25, 2004 | 04:55 PM
slicksilver11's Avatar
slicksilver11
I agree with the gator back - i put a new serpenitne belt on and it started squeeking after a couple of weeks. The gator back is still holding strong.
I thought it was the tensioners, so I replaced them, but it still didn't help.
Old Dec 25, 2004 | 04:57 PM
RedC5's Avatar
RedC5
I sprayed mine with Dura Lube can spray...all is well now. Do not use belt dressing! Lasts for about a year. Cheap fix.
Old Dec 25, 2004 | 05:13 PM
Beardown3's Avatar
Beardown3
Default I'm taking you recommendation
but can I ask a stupid question. How do you loosen the belt to get it off. And how do you tighten it after the fact. Sorry, I've never done this before
Old Dec 25, 2004 | 08:19 PM
Jeffthunbird's Avatar
Jeffthunbird
I had a tensioner fail on my '97. The belt was eaten very quickly after that. Maybe there are some squeeky bearings in there? Worthwhile to check it out before you get stranded.
Old Dec 25, 2004 | 10:00 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
PM sent.
Old Dec 25, 2004 | 10:47 PM
Could be a pulley or the tensioner.
Old Dec 26, 2004 | 01:19 PM
Kenny94945's Avatar
Kenny94945
Could be the water pump bell shaped pully is glazed. Sand and repaint.
To Question About A Squeaky Belt?
