Tire -Size ?
Old Dec 26, 2004 | 11:33 AM
dgibson's Avatar
dgibson
Default Tire -Size ?
I have an '01 vert - stock chrome spoke wheels. Can't afford new wheels right now - but I need new tires. I currently have 30K on the original set - Goodyear Eagle F1 - 245/45/17 - front and 275/40/18 - rear.
First of all I do not know what the numbers mean - other than 17" on the front and 18" on the rear. What are the other numbers ?
I was looking at THe Tire Rack - Can I put - Z06 tires on my existing chrome stock spoke wheels ? ie...265/40/17 - front and 295/35/18 - rear ? First explain ther numbers.
Thanks,
Dennis
Old Dec 26, 2004 | 11:48 AM
1BAD-LS1's Avatar
1BAD-LS1
For example, 275/40/18's on the rear - as you know the 18 is the diameter of the wheel (18 inches).
The 275 is the width of the tire in MM, so in this case - 275 milimeters wide (note that 24.5mm = 1 inch)
The 40 is the sidewall aspect ration of the tread width - in this case 40% of the 275mm tire width or 110mm.
You can safely use a slightly wider tire on the C5 stock wheel but I am no expert - I would not go much wider than a 285 or 295.
Old Dec 27, 2004 | 12:02 AM
Zeek's Avatar
Zeek
St. Jude Donor '07, '11 thru '24
Official Sponsor of the 60 Day VacatioNN
10,000 poster in the "thread" Part II
ttt
Old Dec 27, 2004 | 12:12 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Yes you can run the z06 tires on your stock rims, it will have a little bit of bubble on the sidewalls, which IMO looks great and helps protect the rims a little bit.
Just to toss in here since i see you're not looking for run flats, and you dont' seemingly abuse youre tires too much to make 30,000 miles on them....I am running the Kumho tires i paid 550 dollars <stock sizes> deliever from tire rack, I am extremely happy with them, and plan on buying another set.
Old Dec 27, 2004 | 01:13 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
I went with GY GS-D3 they are a non runflat in stock sizes and they are great
Old Dec 28, 2004 | 12:54 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Using your stock fronts (245/45-17) as an example:
245 = 245mm width
/45 = 45% as tall (sidewall) as the width
-17 = 17" rim OD
Plug some numbers into these tire calculators and you will very quickly get the idea:
http://www.1010tires.com/TireSizeCalculator.asp
http://www.discounttire.com/dtc/broc...o/tireMath.jsp
According to the above mentioned calculators, Z06 tires on stock C5 rims (8.5" & 9.5") would be a problem.
To Tire -Size ?
