Wheel/tire combo, what do ..............
Old Dec 27, 2004 | 07:42 AM
D.K.'s Avatar
D.K.
Default Wheel/tire combo, what do ..............
you guy's/girls think of this idea?
My 99 came with 8.5x9.5" Z06 replica's. I'm happy with the look. The front tires are in bad need of replacing(almost bald), however the rears(275x18) are in great shape.
One of our wheel vendors is offering a Chrome Z06 wheel like mine, in an 18x12. I was thinking of doing this.........
Getting the 18/12's for rear use(I can put on big meat in the back now, which I would like)and buying the tires to go with them. Then putting my current rear wheels/tires on the FRONT. Then, I would have 18x9.5" in the front w/ 275's and 335x18 in the rear(or 315). The vendor claims that the 335's will fit w/o any tubbing.
Would this be feasible?
Old Dec 27, 2004 | 08:42 AM
vetdude's Avatar
vetdude
Feasible, but, unless you don't mind the rear tires sticking out about an inch from the rear fenders feel free.
Old Dec 27, 2004 | 09:05 AM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
The rear will stick out a little but it can be done. You might want to consider the 18/11 with a 305 tire
good luck
Old Dec 27, 2004 | 09:55 AM
Vettegetsmwet99's Avatar
Vettegetsmwet99
i have 18x9.5 in front and 18x10.5 in back with 295 35 in the back and i think that they look perfect, line perfectly with the finder
Old Dec 27, 2004 | 01:20 PM
Yes, you could put the 18x9.5's in the front. I run a 17x9.5 in the front now and it looks good up there.
Old Dec 27, 2004 | 04:38 PM
D.K.'s Avatar
D.K.
JD,
What size tires are u running up front? I would be using 275's and I hope they will fit.
Also, how about the rake from aft to the front. If I'm running 18's on both front and rear, there would be no rake like the stock 18/17 set-up. That is if the profiles are the same too.
Old Dec 27, 2004 | 04:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you currently have 275/35/18's on the back, your plan would work.
If you have 275/40/18's now, and want to move those to the front, the 335's you put on the rear will then be shorter than your front tires. This is a no-no.
Besides looking very bad, you'd have to shut off traction control just to drive the car, as it would certainly kick in during normal driving.
Old Dec 27, 2004 | 04:59 PM
D.K.'s Avatar
D.K.
I currently have 275/40's. What if I used 315's instead, maybe they have more profiles to choose from?
Old Dec 27, 2004 | 05:08 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
The only 315's I know of are 315/30/18's, and they are even shorter in height than the 335/30's are.
I would not use 275/40's on the front, period. Too tall.
Old Dec 27, 2004 | 05:24 PM
D.K.'s Avatar
D.K.
OK what if I used the 17" wheels I currently have on the front and mounted the 275's on them? It would be tight but could 275's be mounted on a 8.5" wheel?
Old Dec 27, 2004 | 05:28 PM
jmzvet's Avatar
jmzvet
The Z has 265s on a 9.5 wheel so I don't think a 275 tire would be the optimal choice for a 8.5 wheel.
Old Dec 27, 2004 | 05:33 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
A 275 usually calls for a minimum of a 9" wheel.
If you;'re resorting to using the 17" fronts you have and need new tires anyways, a 255/40/17 or 265/40/17 is what would work best.
Old Dec 27, 2004 | 08:48 PM
jdmvette's Avatar
jdmvette
Night Owl for life
I've been looking into this issue too. What I've come up with to match a 315/30/18 rear is either a 285/30/18 or a 265/35/18 for the fronts in order to remain a tad shorter than the rear tire, keeping the TC happy.
To Wheel/tire combo, what do ..............
