Window stuck
Old Dec 27, 2004 | 01:08 PM
J1963D's Avatar
J1963D
Default Window stuck
Just dropped off my baby at GM. Passenger side window stuck half way down. Has anyone had this problem? I read the forum all the time ( C2 & C5 ) I have heard of on going electrical problems. I hope I am not going down that road.
Jeff
Old Dec 27, 2004 | 01:13 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Was there any power to the window motor? Any sounds? If not, might be a window module.
Did you check it at all yourself? I wonder if your control switch is properly connected or even a fuse.
The other thing that causes windows to stop in the middle would be going off-track. Is there any chance someone tried to push your window down recently (i.e. Car burgler)?
Hopefully not the latter. Good luck. Let us know what happens.
Old Dec 27, 2004 | 05:59 PM
J1963D's Avatar
J1963D
Default Window Stuck
Thank you for your input, The dealer just called. Bad motor. my vette
will be home tomorrow.
Jeff
To Window stuck
