This is strange...
Dec 27, 2004 | 01:28 PM
St. Jude Donor '08
This is strange...
I installed the skip shift eliminator yesterday, took the car out for a test drive and it worked perfectly. Then this morning I fire it up, pull out of the driveway, and it comes on for about a second. Any idea what's going on?
Dec 27, 2004 | 01:32 PM
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I've got the CAGS eliminator, but my skip shift light still comes on from time to time although I'm not locked out of 2nd......
Dec 27, 2004 | 01:41 PM
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
They light will always work, but the resistor will by bypass the Cags
Do not disconnect the light, you will set a code.
Dec 27, 2004 | 01:55 PM
Dec 27, 2004 | 01:59 PM
Quote:
Dec 27, 2004 | 02:19 PM
My CAGS is disabled with LS1 Edit which also shuts the indicator light in the IP off.
Otherwise, you will see the light when the CAGS is supposed to be energized. But, it won't, since you have the eliminatior installed.
Dec 27, 2004 | 02:57 PM
I was surprised when the skip shift light came on as well. I guess the LS1 edit is the way to go if you don't want the light to go on.
Dec 27, 2004 | 05:13 PM
Did this in my C5 and my C6 but it still works fine
Dec 27, 2004 | 05:21 PM
The light still comes on even with the CAGS eliminator installed. It just allows you to shift to second any time you want.
Dec 27, 2004 | 05:33 PM
Quote:
Same here, the light still comes on with the CAGS eliminator installed.
Dec 27, 2004 | 05:36 PM
Cruise-In V Veteran
St. Jude's Donor '05
