rattling top, need help
Old Dec 28, 2004 | 02:07 PM
rcknusa's Avatar
rcknusa
Default rattling top, need help
The top on my coupe has been rattling for several months, I've tried to have it fixed at the body shop but nothing has been permanent. Anybody have this problem that they solved for good (with or without dealership working on it)?
Thank you for your help.
Old Dec 28, 2004 | 02:13 PM
rcknusa's Avatar
rcknusa
ttt
Old Dec 28, 2004 | 02:21 PM
rcknusa's Avatar
rcknusa
ttt
Help please!!!
Old Dec 28, 2004 | 02:24 PM
JHALL8569's Avatar
JHALL8569
is it rattleing from the back or the front....when i had a coupe it had a rattle from the front of the top and i took the latch covers out loosened the latches and readjusted them really snug and that solved the problem...hope this helps
Old Dec 28, 2004 | 02:30 PM
rcknusa's Avatar
rcknusa
Sorry I left that part out. It is rattling from the back on the passenger side near the post that goes into the hole.
I believe the adjustment mentioned above was performed twice by the body shop guy (who is very good and knowledgable).
Old Dec 28, 2004 | 02:46 PM
rcknusa's Avatar
rcknusa
ttt
Old Dec 28, 2004 | 03:04 PM
Mark-44's Avatar
Mark-44
I put regular size Curad plastic bandages over the alignment holes, installed top - no rattles.
Mark
Old Dec 28, 2004 | 09:46 PM
PaPaChoc's Avatar
PaPaChoc
Mine was rattling right above my head. It took me the longest time to finally figure out where it was! I think I was stopped at the store waiting for the wife when I found it. I took a gum rapper, folded it up and wedged it in the hole where the pin fits. That’s kind of a tacky fix but it works and my top doesn’t rattle anymore and nobody but me knows about it. Well, I guess every body knows now!
Old Dec 28, 2004 | 10:26 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Mark
...now that is really putting a bandaid on it...
never had a loose top in my coupe...
...except when the latch on the right was not fastened...
...the only other rattle I had was from the center latch...
...apparently the rubber bumper came out an dcontinually clattered against the top...
peace
Stu
Old Dec 29, 2004 | 10:52 AM
rcknusa's Avatar
rcknusa
Thank you all very much those are great methods. I didn't think about the center latch until you mentioned it Stuart but I will check that as well.
These are all very helpful and appreciated tips.
Have a great day.
Allen
Old Dec 29, 2004 | 11:42 AM
yellowvette837's Avatar
yellowvette837
St. Jude 15 Year Donor
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
Mine rattles from all the latches and holes
Trying to fix it
Old Dec 29, 2004 | 12:34 PM
leaftye's Avatar
leaftye
Since mine does it too, I may just go at it with a dremel to enlarge the hole. The Dremel fix will look a lot better than felt or bandaids, and may even look like a factory job. (saying that like it's a good thing)
To rattling top, need help
