strange noise...help
Old Dec 28, 2004 | 07:43 PM
red97vette's Avatar
red97vette
Default strange noise...help
I noticed today a noise comming from my rear drivers side wheel. It is only audiable when driving slowly (~30mph and slower), its almost like a squeaking/grinding sound...and i think its comming from the caliper.
My first thought was that the pad as just barley rubbing on the disk.
I drove the car later in the day and the sound was gone and didnt come back... but i donno for how long...
any thoughts?
red
Old Dec 28, 2004 | 08:57 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
could be a brake pad on that caliper, take the wheel off and check the wear on the pads
Old Dec 28, 2004 | 08:59 PM
jeromeunderwood's Avatar
jeromeunderwood
May be time for a brake change... sounds like the wear indicator on the pads.
Old Dec 28, 2004 | 11:16 PM
alanh's Avatar
alanh
I assume you have a 97, if that is correct, it may be time for a new wheel bearing.
Old Dec 28, 2004 | 11:48 PM
mjallen40's Avatar
mjallen40
red
Hey, what are you doing driving that slow? (sorry no real help)
Old Dec 29, 2004 | 02:18 AM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Next time you hear that noise...slowly lift the E Brake handle and see if it goes away...The E Brake shoes have a wave spring that helps center the shoe in the drum...Sometimes they don`t exactly center and rub a bit.
Old Dec 29, 2004 | 02:26 AM
P51tj's Avatar
P51tj
I had the same thing happen once in a different car and found a dead leaf had wedged itself in the caliper...made one heck of a noise . Removed leaf and all was well . Hopefully its no more than that for you! Good luck!
Old Dec 29, 2004 | 11:15 AM
Benpup's Avatar
Benpup
or it could be a small child or a Mustang driver.
But what do I know about who you run over.
Old Dec 29, 2004 | 11:25 AM
srchief100's Avatar
srchief100
And in addition to that; there could have been some "grit" or other foreign object jammed between the caliper/rotor.
Old Dec 29, 2004 | 11:26 AM
SMX's Avatar
SMX
I have the same problem
If I pull up the e-brake slightly it stops.
Old Dec 29, 2004 | 02:09 PM
Boozman's Avatar
Boozman
Sounds like pads need replacing
Old Dec 29, 2004 | 06:06 PM
red97vette's Avatar
red97vette
i was thinking that the brakes could be wearing...but none of the other indicators are squeaking, and wouldnt the fronts go before the rears because they take much more of the braking power?
red
Old Dec 29, 2004 | 06:17 PM
12stepvette
e-brake shoe not centering...weak or improperly seated wave spring.
Old Dec 29, 2004 | 06:24 PM
400hp's Avatar
400hp
red
It all depends, when was the last time your front pads were changed?
To strange noise...help
