How often do you change spark plugs?
Old Dec 29, 2004 | 08:26 PM
Blue Lion's Avatar
Blue Lion
Default How often do you change spark plugs?
I have a 2000 coupe, 33k miles, and I drive it only for fun. When should I change my spark plugs? I'm having some routine maintenance done soon and could add this to the list. She's running fine right now. Thanks!
Old Dec 29, 2004 | 08:43 PM
nuck's Avatar
nuck
Not before 60k on any car with platinum plugs.
Old Dec 29, 2004 | 08:48 PM
Haven't done it yet, but I only have 25K on the car now. If I ever get my headers, I will do it then. Otherwise, probably not for a long time.
Old Dec 29, 2004 | 08:53 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I changed mine out for NGK's Tr 55's Iridium. At 30k.
Old Dec 29, 2004 | 09:37 PM
c5chris's Avatar
c5chris
I had my car smogged this year and the guy there said that plugs on the C5 will last you a good 50-60K miles without changing. I was concerned if I needed to change them before smogging (I changed the engine oil the night before) to have my chances of passing the test better. He said that there is no need and they are good to last for a while since it is hard to get to them (due to the exhaust manifold).
If you are changing to LT headers, that's the perfect time to change the plugs.
Old Dec 29, 2004 | 09:38 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Whenever I need a good 2 hours away from the wife and kids
Then there is the oil change...
The underside scrub...
Cleaning the inside of the rims...
Engine detail...
Well...you get the picture
Peace
Willfulone
__________________
..................Click for
Old Dec 29, 2004 | 09:41 PM
T_Vert's Avatar
T_Vert
i only have 29k on my car and ive changed my plugs 3 times. i change em at least once a year. They're cheap and easy to get at.
Dave
Old Dec 29, 2004 | 09:42 PM
USA-VET's Avatar
USA-VET
every 15k
Old Dec 29, 2004 | 09:43 PM
CCA Corvette Parts
Dave
Except that last one
Peace
Willfulone
Old Dec 29, 2004 | 11:17 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
but I am at 43000 miles
Old Dec 29, 2004 | 11:28 PM
Memphis Milner's Avatar
Memphis Milner
Dave
My brother was like that, until he stripped out the threads!
T_Vert's Avatar
T_Vert
Peace
Willfulone
the plugs on the c5 are cake. I can have em all out and replaced in 1/2 hr at the most. I'm not sure what people have a problem with. Another thing to note is that I've always used the cheapest .99 plug made for the c5 and i notice no ET difference or idle difference! I used to do this on my blown mustangs and also never noticed any loss in ET/MPH, fuel mileage or quality of idle.
Dave
Old Dec 29, 2004 | 11:30 PM
T_Vert's Avatar
T_Vert
antiseize is you friend.
Dave
Old Dec 29, 2004 | 11:33 PM
99torchredlb's Avatar
99torchredlb
have 67,000 miles haven't changed them yet.
Old Dec 30, 2004 | 06:21 AM
Patman's Avatar
Patman
I got my car with 32k on it and almost right away had it dyno tuned. We immediately noticed it was getting 7 degrees of KR, so I pulled a plug and it looked horrible! The platinum was gone, so the gap was too high. I immediately put in some copper NGKs and it went to 0 degrees of KR. FWIW, most of the other 7 plugs were also missing the platinum pucks.
So the OEM plugs are not good for even 30k!
Plug swaps in the C5 only take 30-40min, so you might as well just go with NGK TR55 coppers, and change them once or even twice a year. That's my plan.
Old Dec 30, 2004 | 06:55 AM
Richin Chicago's Avatar
Richin Chicago
There is a good chance that the plugs, in your 2000, if original, are in pretty sad shape. In my opinion Delco did a very poor job in joining a small platinum "puck" to the boitom electrode. This is what made the plugs platinum but it has been my experience that a lot of the plugs you see pulled no longer have this puck. This causes a wide gap and brings the plug's life back to conventional (whch means 36K miles is a lot). Take a look at the picture below (borrowed from another forum member) The top plug is missing the platinum puck.
I had 4 of the 8 missing when I pulled my plugs. I switched to iridium plugs which are the latest greatest. The metal is so tough they can go to a smaller profile which takes up less volume in the combustion chamber. This means more exposed spark and less intrusion.
I used the TR55IX plugs by NGK. www.sparkplugs.com
Old Dec 30, 2004 | 07:55 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I have changed mine 6 times in the last 30,000 miles
VR
To How often do you change spark plugs?
