Quick question on CLB results
Old Dec 30, 2004 | 02:14 PM
brucksch's Avatar
brucksch
Default Quick question on CLB results
I noticed since installing the CLB that I can now change the seat memory between 1 & 2 while driving. Is this a result of the CLB?
Old Dec 30, 2004 | 02:25 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Thats also not good, thats a safty issue. Did GM do the CLB? or did you? If you hit that while driving you could be screwed, expecally if anthoer person driving the car is alot taller or alot shorter. Like me and my wife I am 5'11 she is 5'1
Old Dec 30, 2004 | 02:30 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You should have been able to do that before. I think the deal is you can't program memory settings while moving, but you can switch between the settings while moving.
In fact, a neat trick is to set the memory 2 setting the same as 1, with the exception of moving the left mirror setting out more. When rolling down a freeway onramp, hit the #2 button to move the mirror for better rear visibility while merging. Once on the freeway, hit #1 to reset the mirror back to normal.
Old Dec 30, 2004 | 03:09 PM
bekdad's Avatar
bekdad
Hey, good idea. Also could be useful when parking. Set the mirrors to look down at curbs, pavement markings, etc.
Old Dec 30, 2004 | 04:58 PM
Dirty Howie's Avatar
Dirty Howie
Use memory 3 to move passenger mirror out and up...to see LEO hiding at top of onramps!!
Old Dec 30, 2004 | 07:23 PM
To Quick question on CLB results
