Lowering my car? How much?
Old Dec 31, 2004 | 04:23 PM
marv1's Avatar
marv1
Default Lowering my car? How much?
This is my 2002 vert currently at stock height. What do you believe I should lower it to . Im trying to go with a aggressive look. I have tinted the windows and have installed the rear blackouts. I will be doing the front soon. Any other exterior mods that you may think would look good on my torch red vert.
Old Dec 31, 2004 | 04:43 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Slam your car ... all the way on the stock bolts. It's not too low, the ride is better and it just looks bada$$ ...
Not my car, but looks mean to me ... Just my .02
How about the black lower fascia ..
Old Dec 31, 2004 | 04:48 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
They always look better low if you're prepared to do the work and put up with the hassles of a lowered car.
Old Dec 31, 2004 | 04:59 PM
THEO C5's Avatar
THEO C5
Truer word have never been said.....
It's a lot of hassles...most people don't talk about it, they just say slam your car.
None the less I did to my car. Now I can't drive it to certain places.
Here's a before and after so that you can see what to expect. It doesn't look like much difference but believe me it is.
Before
After
Old Dec 31, 2004 | 05:03 PM
GaryZ06's Avatar
GaryZ06
Mine is pretty low and I have no problems at all.It all depends on how good your roads are and how you drive it.I rarely scrape the front rubber spoiler.
Old Dec 31, 2004 | 05:06 PM
MSGvette's Avatar
MSGvette
Car looks great lowered. If your concerned about scrapping. Get A&A's Roller Rocker and Frame savers. I use them on mine.
Old Dec 31, 2004 | 05:14 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I lowered my car on stock bolts with no bushings cut.... it dropped about an inch and a half after the first year, now five years later it's down about 2 1/2 inches from stock.. and still on stock bolts with no bushings cut..
Old Dec 31, 2004 | 05:15 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I'm with ET on this. About an inch on stock bolts with no cut bushings.
Old Dec 31, 2004 | 05:23 PM
Morzoff's Avatar
Morzoff
Lower it all the way on the stock bolts, if you want more you can cut the bushings
Old Dec 31, 2004 | 11:27 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
[QUOTE=Evil-Twin]I lowered my car on stock bolts with no bushings cut.... it dropped about an inch and a half after the first year, now five years later it's down about 2 1/2 inches from stock.. and still on stock bolts with no bushings cut..
/QUOTE]
Evil
That is interesting. My is lowered an inch without cutting the bushings. It has been only 8 months. I hope it goes down another inch. Any explanation ? I am not an engineer but love to hear a good explanation.
Old Jan 1, 2005 | 03:39 AM
gmosley's Avatar
gmosley
Default lower longer
it would seem to me that evils car has gotten lower over the years due to the leaf spring becoming weaker over the years all that weight on the spring over time has stressed it and probably weakened it
not an engineers answer but sounds pretty good in theory
Old Jan 1, 2005 | 11:14 AM
Davesredvette's Avatar
Davesredvette
Start with lowering all the way on stock bolts, should only take you about an hour. My guess is that you will want it lower after that but it's a good place to start. Generally ride doesn't suffer much until you go beyond stock bolts.
Yes, Evil's car is not the norm so don't expect it to be totally slammed on stock bolts like his is.
Good luck and post pics after your done!!!
Old Jan 1, 2005 | 11:22 AM
blazeone's Avatar
blazeone
Plain and simple to me the 4X4 look sucks
Old Jan 1, 2005 | 11:31 AM
Pilot1996's Avatar
Pilot1996
I've not done it to mine...they look better lowered, by I'm scraping the air dam every time I pull into my driveway... I can appreciate the looks, but I don't want the hassle.
My $.02.
Flame suit on.
Mac
Old Jan 1, 2005 | 11:40 AM
YO-EL's Avatar
YO-EL
Whats the hassle...?
The air dam is flexible...
It sounds bad, but its only the lower plastic that rubs, and its probably not even flexing up anyway..
Old Jan 1, 2005 | 12:31 PM
GaryZ06's Avatar
GaryZ06
Yes it looks really low and I am sure it is but Evil has bigger wheels and tires which will make it look even lower....
Old Jan 1, 2005 | 02:09 PM
jrose7004's Avatar
jrose7004
I lowered mine as low as it would go on stock bolts and cut the rear bushing about 3/4ths!
To Lowering my car? How much?
Old Jan 1, 2005 | 04:34 PM
Sportsdude's Avatar
Sportsdude
At the least lower on stock bolts
Old Jan 1, 2005 | 06:42 PM
gmosley's Avatar
gmosley
Default not true
i put bigger wheels and tires on my altima at the same height i didnt add any height to the original diameter of the factory wheel and tire even though the wheels were 2 inches bigger however the look was horrible the big wheels with lower profile tires gave it a 4x4 look and made the wheel gap even more noticable than on factory wheels
actually evils rims and tires are shorter than the factory wheel and tire on the front by 1/2 inch so actually his car will be slightly lower (1/4 inch) than another c5 lowered on factory bolts due to smaller tire diameter
however the back is 1/2 inch larger so it would be 1/4 inch higher in the rear
but i think you missed what he said when he stated that it got that way over 2 years meaning the suspension eventually sagged more than before due to stress and what not as well as the leaf spring giving more over the years
Old Jan 1, 2005 | 09:31 PM
Old Rotor Head's Avatar
Old Rotor Head
Go full down on the stock bolts and you won't be sorry. Rides great....looks even better.
