C5 for Dummies
Old Jan 1, 2005 | 09:23 PM
Nates99ss's Avatar
Nates99ss
Default C5 for Dummies
LOL, you know all the help books titled "whatever for dummies" well...Im sure this would be in this book, but how do I change my headlight bulbs? I mean I know how, but Id like a link to a site with pictures. Im at a friends and I want to put these in, but hes harldy has any tools and I need to see what Im doing. Thanks.
Old Jan 1, 2005 | 09:28 PM
jdmvette's Avatar
jdmvette
Night Owl for life
All you need is a phillips head screwdriver. There are 3 screws holding the shroud surrounding the lights. Take them off and then slide your hand behind the light and find the bulb. Twist the bulb and pull it out from behind the light.
Remove the bulb from the harness and plug in the new bulb. Be careful not to touch the bulb with your fingers. Twist the new bulb back in the housing and repeat for the other side.
Very easy and takes 10 minutes.
Old Jan 1, 2005 | 09:34 PM
Nates99ss's Avatar
Nates99ss
I just went and looked at it, and as I already said, felt stupid for asking. If I need to adjust where the bulbs are aimed, can I do that also?
Old Jan 1, 2005 | 09:52 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Adjusting the lights are a PIA. You need a torx wrench #15 I believe. The one that comes with your CLB kit works perfectly. Do a search on aiming them if you need to...it's hard to discribe but there are posts about it.
Old Jan 1, 2005 | 09:56 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Is a re-aim required when switching from stock to xenon bulbs?
Old Jan 1, 2005 | 10:03 PM
Nates99ss's Avatar
Nates99ss
Thanks for the quick replies guys
Old Jan 1, 2005 | 10:04 PM
chocoholic's Avatar
chocoholic
There probably are links to this online but there already are photographs and instructions on how to change the bulbs in your owner's manual and that certainly is online if it's not in your car.
However, as above, it's "simply" a case of removing the bezel and changing the bulbs. The "simply" may depend on the size of your hands though. Likewise, aiming the headlamps is pretty much a standard operation too.
Old Jan 2, 2005 | 01:24 AM
ALLEGRO's Avatar
ALLEGRO
Default C5's For Dummies
I thought that was the purpose of this forum?
To C5 for Dummies
