[Z06] water spots on back window??
Old Jan 1, 2005 | 10:21 PM
1320IN9's Avatar
1320IN9
Default water spots on back window??
my zo6 has some water spots that will not come off the back window, anything i can do to get them off the glass??
Old Jan 1, 2005 | 10:39 PM
dragon84's Avatar
dragon84
I have the same thing. I think it is from spray wax from a car wash...... maybe???
Old Jan 2, 2005 | 12:27 AM
xilr8n's Avatar
xilr8n
I think I heard that vinegar would do it. I know it acts like a delimer.
Old Jan 2, 2005 | 12:36 AM
DsC5's Avatar
DsC5
I would try claying first, then vinegar, failing that, Zaino Z12 makes a good glass cleaner that has worked on water spots for me in the past.
I've also heard that 0000 steel wool (presumably with some sort of liquid cleaner to avoid scratching) works well.
Old Jan 2, 2005 | 10:10 AM
barondw's Avatar
barondw
Clay, vinegar and NO steel wool. If that doesn't work try plastic cleaner which will not harm the glass surface.
Old Jan 2, 2005 | 10:37 AM
Thud's Avatar
Thud
Maybe the water spots are on the other side of the glass.
Old Jan 2, 2005 | 10:42 AM
knkayotte's Avatar
knkayotte
Only thing that ever worked against AZ hard water is A-MAZ. Tried everything mentioned here. Even then it takes some elbow grease.
Old Jan 2, 2005 | 10:45 AM
Kschwamy's Avatar
Kschwamy
Griot's makes a window polish/cleaner that does a good job. It comes in a very fine grade for minor work and then a heavier cleaner for more stubborn water spots. Used it on my wifes 98 when we bought it used. It had some real water spot problems and used the heavy cleaner with an orbital buffer and it did a great job of bringing the window back to a new appearence.
Old Jan 2, 2005 | 10:46 AM
hoogbest's Avatar
hoogbest
Default Water Spots
NEVER, EVER wash your car after it has been sitting in the sun even if you move it to the shade. Feel the glass and car body if both are cool to the touch then you should be ok. If the glass and/or body are hot the soap, wax or other material's residue spots will etch into the glass and/or body and it will be there permanently. After a few years it will lighten but it never disappears.You may be able to find something to remove it........ I never did. Fortunately I learned my lesson before I bought my Z! Thank God!
Old Jan 2, 2005 | 11:19 AM
weendoggy's Avatar
weendoggy
OK, are you ready for this? I use Wenol polish. Yep, polish. It'll take off water spots pronto! No, it doesn't hurt the glass. No, it won't scratch the glass. Yes, water beads off just fine. Yes, I've used it many times on several cars. I follow that up with Brilanize plastic cleaner. No problems at all.
Old Jan 2, 2005 | 02:10 PM
Thunder22's Avatar
Thunder22
rubbing alcohol takes water spots right off of glass. it also takes tree sap off of paint without harming the paint, just wax the area when you're done (the paint that is, not the glass)
Old Jan 2, 2005 | 05:06 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
I had the same problem on my '97 front glass also. I tried most of the above but did not help. What finally worked for me was Dupont rubbing compond, the old fashion stuff in the tin.
Old Jan 2, 2005 | 05:17 PM
Hercdriver's Avatar
Hercdriver
I have the same spots on all the glass of my car. I have it on all the windows and the rearview mirrors. I even took it to the dealer because it ticked me off that I could not get it off. They used a little acid and that helped a little but still didn't work. I don't know what to do. It irritates me! I am glad I am not the only one this has happend to. It really is not a big deal. I am the only one that notices it!
Old Jan 2, 2005 | 08:19 PM
slong's Avatar
slong
Give citric acid a try. Same stuff found in the peels. We use it to passivate our water system piping such as WFI "Water For Injection". Works great on ground water deposits.
Old Jan 2, 2005 | 09:53 PM
1320IN9's Avatar
1320IN9
well, i got the water spots off, i mixed up a cup of half water, half white vinigar and scrubbed the glass with 000 steel wool, just dunk the wool pad in the mixture and scrub away, it worked great and no scratches on the glass, all the water spots are gone and the glass looks brand new, then i waxed the glass to prevent this from happening again......
Old Jan 2, 2005 | 10:15 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
TRY A RAZOR BLADE!
Old Jan 3, 2005 | 06:19 AM
Sam's 66's Avatar
Sam's 66
Zaino glass cleaner..........
Old Jan 3, 2005 | 01:37 PM
90 Corvette ZR-1's Avatar
90 Corvette ZR-1
Try some Vanilla Moose if you still can't get it off.
To water spots on back window??
