Dash Vibration
Just thought I'd pass this along - I was getting an annoying vibration around the area of the clear plastic lens that covers the speedometer, etc. When I pressed on the lower right corner of the plastic lens, it stopped. Turned out that simply tightening the two torx screws above the lens did the trick.
I had a squeak with the center console radio and HVAC trim piece. I eneded up taking it all apart and put some grease on the tabs that centered it when it slid into place and presto -- no squeak.
I have a rattle somewhere the glove box that I need to hunt down next, but it's not that bad and I suspect the glovebox itself is just out of alignment and/or needs to be tightened.
