[B]hows my aim[/B]
Old Jan 3, 2005 | 06:09 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Default [B]hows my aim[/B]
I replaced stock headlight bulbs with xenon. Do I need to re-aim lights due to the different bulbs?
Old Jan 3, 2005 | 06:31 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
just make sure the bulbs are seated correctly.. If you didn't mess with the adjusters , you shouldn't have to re-aim...of course, I could be wrong.
Old Jan 3, 2005 | 06:36 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
In case you do have to adjust ... use your garage door. Put a line of masking tape for reference. Since HID's have a wider and higher beam pattern spread, you can/should lower them a bit to keep from blinding oncoming traffic. You'll still have a good field of view.
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
I would think not, since the bulb sits in the housing and you don't have to move the housing to change the bulb
To [B]hows my aim[/B]
