I bought the car used and only one of the remotes worked from the begining. The guy I bought the car from said that I could get on the internet to get the unused one to work. I never did though.
Now my original remote is dead. Do I need to just change the battery out or can I do something else? Thanks in advance...
From: the GOCC are everywhere, even back from "band camp"
If you change the battery, or remove it for any reason you must retrain the remote. Very easy to do, but only if someone tells you to do it. Stand by the left side A pillar and press both LOCK & UNLOCK buttons simultaneously until the horn honks. If that doesn't fix it then your fob (or RKE) is dead.
Bruce
Bruce
Switch out the battery first and then do a relearn procedure to match the remote to the car. Hopefully that will solve the problem. If not, you may have to get a new remote. They can be found in the for sale section (be sure to get the one that will work with your car) or a dealer can get them for you.
cool...what do I do kust tell then I need a battery for my Vettes fab?
I usually take them in and the salesperson just looks at the type of battery in them and replaces it.
As far as getting another remote I found mine on eBay for about $35. You can also post in the C5 Parts section - make sure you get the same part number as the one you have.
