Amsoil going in the trans
-Synthetic Extreme Pressure Lubricant
-Long Life Synthetic Gear Lube
-Synthetic Gear Lube
Can someone tell me which one going in the tranny and what goes in the differential?
http://www.amsoil.com/products/atf.html
They changed their gear lubes (differential fluid) since I changed mine. But
this is the one I'll get next time around;
http://www.amsoil.com/products/svg.htm
Someone told me to use ATF in the M6 but that didn't sound right to me, guess I was wrong.
Thats an awesome looking sled by the way... if I didn't go with black I would have gone withe the Mag.Red.
Have you it dyno'd with those mods?
Lower right in the sig are the dyno #'s: 410rwhp/374rwtq
I too was concerned about the correct tranny fluid, but thats the stuff!
Another forum member set me straight.
Who do you trust? The people who desgined the tranny or someone who sells fluids? These trannies use carbon blocking rings in the syncros and need the proper friction lube to work right...
Better not to guess... use what the Manuf recommends.
mike
http://amsoil2.cpinternet.com/script...msoiloaf:index
Just enter the year of your car and click on "build list". Follow the easy instructions and continue entering information until the build list appears on the right side of the screen...pretty neat stuff from Amsoil.
