Recommendations
Old Jan 6, 2005 | 01:50 AM
58patent58's Avatar
58patent58
Navigator
Default Recommendations
I am new to the forum and to Vetts.
So far, I have not had fun with the car. Now the I can't get the car into gear.
A member of the forum told me that I need to "bleed" the system as a possible solution. I received the instructions. Even though the instructions are not too complicated, I am ready for the task.
Can anyone recommend a good mechanic in San Marcos, CA area or North County (San Diego)? I will need to tow the car and Dealers will just take my left kidney for it. So, a good Vett mechanic would be preferred.
Old Jan 6, 2005 | 01:57 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
"Clutch fluid"???
Old Jan 6, 2005 | 02:09 AM
58patent58's Avatar
58patent58
Navigator
Opps
Old Jan 6, 2005 | 02:19 AM
NSTG8R's Avatar
NSTG8R
.. ok sparky, put down the wrench.
when is it not going into gear? always, only sometimes, while i'm racing .. ?
Old Jan 6, 2005 | 03:47 AM
58patent58's Avatar
58patent58
Navigator
At this point, when the motor is running. The clutch is Very soft almost 3/4 the way down, then it is just soft.
I checked the master cylinder and fluid is there. Over the weekend, the car worked fine. But now, I am lucky it I can get in gear from N. Even when the motor is not running, I can not get in R.
To Recommendations
